Sunroof won't close
Old 06-19-2010, 08:57 AM
mxh3901's Avatar
For some reason, my sunroof wont' close. When I pressed the latch switch to close the sunroof, it will go through the process of closing then it pop up (tilt) then come back down and stay open about 1/4 size. I don't why it won't stay stay close.
Old 06-19-2010, 09:33 AM
Bteljuice's Avatar
press the button to tilt up and keep holding it till it does the whole process. The sunroof will start to open and close. It will do an entire opening then close fully. When it is fully closed, you can remove your finger from the button. That way you would have done a reset to the sunroof and will work properly.
Old 06-19-2010, 10:09 AM
mxh3901's Avatar
I tried pressing the button forward to close then backward to open. It would open fully, but not close. I'm not sure what button to press to tilt up.
Old 06-19-2010, 10:36 AM
rctmthouse's Avatar
I think there is something wrong with the close mechanism but as for tilting, I always thought that you push the button in, up towards the roof to tilt it open. May be you can unplug the battery to reset it and try it again.
RCT
Old 06-19-2010, 11:30 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Did you try initializing the sunroof?
Look here for more info:
https://5series.net/forums/gallery/i...g-the-sunroof/
Old 06-19-2010, 12:37 PM
Bteljuice's Avatar
you have to press it upward(towards the ceiling, let your finger perpendicular to the button and press it and hold it).
Old 07-15-2010, 07:49 AM
fnc
fnc's Avatar
I found this helpful
Sunroof Initialization BMW 5 Series E60 E61 https://wiki.bentleypublishers.com/x/AgBEB
Old 03-16-2015, 03:21 PM
Ewbcpa's Avatar
My Ride: 2007 530i
Cool Worked like a charm
The process worked like a charm. Thanks for the assistance.
Old 11-12-2016, 05:32 AM
wtlb's Avatar
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior MODs: Orion V2s 3000K H8 Yellow Fogs Matte Black Kidney Grills 20" Miro 111 Hankook V12 Tires H&R Sport Springs Special coding via Simon (dbl flash hazards, digital velocity, etc.) LED Side Markers from Trinity Autosports LED License Plate Lights from Trinity Autosports Carbon Delete BMC Air Filter RPI Scoop RPI GT Exhaust Future MODs: Mtech Kit KW Variant 2 Coilovers CIC Retrofit Upgrade Audio System
Thank you so much. This is very helpful. I will try initializing my sunroof today.
Stuboski
11-05-2021 06:58 AM
LandRange
10-05-2015 08:47 AM
cbdoya
09-15-2015 06:09 AM
Tsubasaftl
09-12-2015 01:34 AM
LandRange
09-06-2015 10:39 AM
Quick Reply: Sunroof won't close
