Sudden high oil consumption '06 n52 100k m
Old 10-11-2016 | 12:15 PM
ukr's Avatar
ukr
My Ride: 530i n52
Default Sudden high oil consumption '06 n52 100k m
Started having high oil consumption..needing a quart every 3k m...before it was about 1-2 quarts in 15k m change interval. I'm not seeing any leaks and can't detect any blue smoke from the exhaust. Started happening suddenly, already used 4 quarts with 3k m still left before oil change.
Any ideas what it could be? Something with crankcase oil separator maybe?
Old 10-11-2016 | 06:52 PM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
you might not notice a leak if its dripping down onto the plastic under carriage panels
Old 10-12-2016 | 08:17 AM
ukr's Avatar
ukr
My Ride: 530i n52
Inspected everything underneath and not seeing anything leaks or wet spots.
Ordered new spark plugs, will see If I can spot anything unusual when I remove the old ones. Otherwise the engine runs well.
Old 10-12-2016 | 01:56 PM
StasGS4's Avatar
You will likely need new valve seals. Search you tube for a video on how to diagnose bad valve seals on N62 engine. Also check out the All German Auto website. They sell a tool that allows you to changes that without excessive engine disassembly.
If this is your problem and you take it to the dealer it will cost thousands of dollars to fix.
hmilycar
F10 Discussion
10-11-2016 12:37 PM
drew259
E60 M5 Discussion
10-06-2016 08:21 AM
emonahan33x
09-30-2016 06:39 AM
LeeGU52
09-26-2016 12:48 PM
Darren Price
09-13-2016 08:42 AM
Quick Reply: Sudden high oil consumption '06 n52 100k m
