Style 128's on my 535xi
Old 03-09-2011, 01:10 PM
AchtungE60's Avatar
My Ride: E60 530i
Originally Posted by medik13
Yeah and it is useless. It gives the same info that the ones without taking rim diameter into consideration do.
Can you post a link of the one you're referring to? Perhaps we're speaking of different ones.
http://www.1010tires.com/WheelOffsetCalculator.asp
It takes everything into consideration really. Your BMW tells you the recommended tire sizes. I came with 18x8 ET 20 w/245/40/18 rubber.
I wanted to upgrade to 19 or 20. I chose 19 based on several factors.
Car specifically calls for (in the doorjam) 245/2519 and 275/30/19 which will give you the SAME overall diameter as the stock setup.
I have style 128's ET 14 on my rear which is JUST perfect with no rub, no spacers and hold specs.
Overall diameter is overall diameter of the tire, who cares about the diameter of the wheel as it should be an obvious thing.
Old 03-10-2011, 09:51 AM
JJK
JJK's Avatar
This is probably a dumb question, but can anyone tell me the best places to buy OEM rims? I'm assuming there has to be other places other than the dealership, right?
Old 04-17-2011, 04:51 PM
Lugnut2683's Avatar
My Ride: 535xi
Engine: N54
Mazekid, looks sick!!! I was thinking about this same setup on my xi (128s), and wanted to know where you purchased them from? May I ask how much? Thanks!
Old 04-17-2011, 09:28 PM
mazekid15's Avatar
1550$ NEW. FROM A BMW DEALERSHIP IN NEWPORT RHODE ISLAND. I WAS THINKING OF SELLING MINE AND GETTING ANOTHER SET BUT I DUMPED 1000$ IN MICHELIN PILOT SPORTS A/S... ID BE ASKING TO MUCH
Old 04-17-2011, 10:33 PM
jg7879's Avatar
Looks good!! Def. Needs a drop! I suggest H&R sport springs, it will look so much better after the drop.. Good luck and thanks for sharing the cool pics!!
Old 04-18-2011, 06:11 AM
mazekid15's Avatar
I did drop it already
Old 04-18-2011, 06:22 AM
Percy_991's Avatar
My Ride: E60 530d MSport Auto, 19" 172 Spiders on ContiSports 2's, Pro Nav, Adaptive Xenons, Bruce M's V6 Rear LCI Cables/Lights, Number plate LED
Try finding a local Bavarian motor works they may be able to help. Ask your local BMW dealer where you may find one
umichchris
12-07-2015 03:33 PM
whoyuwit
09-18-2015 12:42 PM
aznfujikiddd
08-09-2015 09:04 AM
baro1220
07-24-2015 08:01 PM
carid
07-24-2015 03:33 AM
Quick Reply: Style 128's on my 535xi
