Stuck in park
My Ride: 2008 BMW e60 550i
Stuck in park
HELP!
I have a e60 2008 BMW 550i automatic transmission rwd and it is stuck in park.
Starts, runs, when I shift to D or R it goes right back to park.
I used a Foxwell scanner and have 2 codes:
Active Steering 61 40 AL: Redundancy comparison, drivers steering angle
Dynamic Drive 5D60 ARS: Oil-level switch
Sos
Before I got the Foxwell scanner I was convinced that the mechatronics sleeve was broken and it would be an easy replacement but the sleeve was not damaged and now I cannot perform the full transmission fill procedure because it does not shift out of park.
Bdon44 (07-29-2020)
The mechatronics sleeve is set properly, the tab was aligned and the mechatronics unit was tightened to exact torque specs. I appreciate all the help, does anyone have a pdf or link to the Service Manual for my e60 2008 550i?
2008 BMW 550i M sport RWD
Stuck in park
My Foxwell scanner is reading these codes
5 Dynamic stability control DSC8 DSC/DXC
- 6DEC DSC: Interface, active front steering
6 active steering AFS
- 6146 AL: Control unit cannot change active mode, undervoltage
- 614A AL: Motor position angle: not initialized
Stuck in park
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
You may need a new szl but that had nothing to do with the car not going into gear. I forgot previous posts but was this car shifting before the work that was done if so you're going to have to do it all over again there's something you missed.
I am assuming your szl was bad before all of this. Is your battery good also
DavidF
04-28-2012 12:50 PM
