5Series.net - Forums
-   -   Streptonic Gearbox (https://5series.net/forums/e60-discussion-2/streptonic-gearbox-1833/)
KYRIACOS 07-20-2004 01:11 AM
Can any one tell me the main differance between the D and DS mode in performance terms. Does the cars accelarate faster in the DSport mode???
Thanks
Kyriacos :D
sj3 07-20-2004 04:20 AM
KYRIACOS: DS will wait longer, i.e. higher rev points, to up-shift than D. DS uses a more "aggressive" or sporty shifting algorithm than D does. Hope that helps (HTH in internet speak!). Also, to get to the semi-manual mode, where you can shift yourself, you need to be in DS mode first.
Sam
Iceman 07-20-2004 06:13 AM
And when you are in DS you can push the selector forward or pull it backwards to shift gears. On your display you will notice the gear you are in, M1, M2, M3... M stands for manual. You can end the manual or DS mode by just pushing the selector over to the right and you are right back in the D mode.
535D Sport 07-20-2004 08:36 AM
How do you get from manual back to DS mode ?
Iceman 07-20-2004 08:46 AM
Push the selector lever to the right into D and right back to the left into DS.
535D Sport 07-20-2004 09:31 AM
What i meant was can you return to sport mode without going back into D first.
Iceman 07-20-2004 10:05 AM
No. :(
But it only takes half a second...
Jimbo 07-20-2004 10:40 AM
I've read somewhere else that the DS mode does not go into 6th gear.
Anyone else confirm this?
kscarrol 07-20-2004 10:50 AM
can't absolutely confirm, but the other day I was cruising down the interstate and saw that I was going to need to punch it to jump into another lane, so I moved from D to DS and the car dropped from 6th to 5th gear before I hit the gas pedal. It definitely uses the higher RPM, now whether it would eventually shift to 6th if I was cruising at a high enough speed, I don't know, but just doing 65 mph or so, holding the gas pedal steady, it moved down in gear and stayed there until I got up to speed and moved back to D, then it shifted back to 6th gear.
skidster 07-20-2004 11:18 AM
doesn't shift to 6th in DSauto; can be shifted to 6th is DSmanual
and DSmanual will eventually shift even if you don't - it's clever enough to work towards a non-blownup engine policy B)
