Strange transmission noise (video attached)
Hi,
I have a 2007 525i with 232k miles on it
I got changed transmission fluid, all sleeves, and selenoid.
This noise started 10k miles after all this stuff. I complete adaptation reset with inpa.
Noise from 3rd to 4th gear and 4th to 3rd gear. Both downshift and upshift. Other gears are very smooth. I was trying record a video. I couldnt hear any noise in the video. Then I saw this video on youtube. I got exactly same issue with same gear.
If I dont push gas pedal while shifting, noise decrease.
https://youtu.be/p0x-vqJx6cg
I opened the fill plug today nothing was coming. Then I added 2 lt of ATF. It started to come. Then I closed fill plug.
So I been driving for 20 miles now. nothing changed. I have same noise.
Engine: 3.0 B58; 3.0 M54
What made you reset transmission adaptations. Did you open up the transmission and change clutch plates or something?
So you drove 10k miles with the fluid 2 liters low and you felt no issues with shifting. You may have ruined the transmission.
As much as I know, selenoids and transmission fluid replacements are enough reason for reset.
Yeah I dont have any problem except 3rd to 4th noise. I drive too many bmws. So other gears are like they should.
My Ride: 2010 Bmw 535i white msport
I have a 2010 bmw e60 m sport with the same issue , vibration under armrest at acceleration from 2nd to third and 4th , if I don’t accelerate hard than it is less wild. Checked guibo and serviced tranny. Only one last thing to check center bearing bushing
Good guesses - I'd look at the rear diff bushings as well, though it could be a whole lotta other things (anything that can transfer drivetrain vibrations to the body, including bad control arm bushings),
mtylerrose
Mar 21, 2023 05:56 PM
