Strange "ticking" noise from front of engine
Old Dec 22, 2009 | 12:05 PM
Jake545i's Avatar
My Ride: 2004 545i Sport, 6spd Orient Blue Metallic Complete MTech Kit
Hello everyone,
I'm hearing a "ticking" noise from the front of the engine. I originally thought it was a valve noise, but after popping the hood, and listening carefully, I have located the noise to the front of the engine, near the belts.
Any ideas what it could be? Perhaps something that is driving the belts? Alternator, A/C compressor, etc?
Thanks in advance!
Jake
Old Dec 22, 2009 | 12:29 PM
BMWRINO's Avatar
If you've made any enemies recently, I'd run away as fast as you can from your car... could be a bomb
Old Dec 22, 2009 | 12:35 PM
billeul's Avatar
Could be the water pump. I'm hearing the same thing. Passenger side, front of the engine.
Old Dec 22, 2009 | 01:06 PM
Jake545i's Avatar
Talking
Nice.....Do I cut the red wire, or the green wire????
Old Dec 22, 2009 | 01:08 PM
Jake545i's Avatar
Hmmm, water pump? That would be somewhat of a relief.....I'm hoping it's not drivetrain related.
Does yours seem to get louder as time goes on? I originally heard this sound a few months ago, however, very faint. But lately, my 545i sounds like it's powered by a Detroit Diesel.....
Thanks,
Old Dec 22, 2009 | 01:29 PM
blindboy79's Avatar
I had the same problem on my 07' 530. Brought it in 2 times for ticking in the engine. First time they replaced the camshaft and the lifters and told me the problem was fixed. Second time i brought it in the car spent two weeks in the shop while they replaced the entire cylinderhead and all of the components. Cost bmw around 10k the second time.
hope that helps
Old Dec 22, 2009 | 01:32 PM
Jake545i's Avatar
hope that helps
hmmmm, well water pump scared me a whole heck of a lot less.....but thanks...
Old Dec 22, 2009 | 01:54 PM
Kzang's Avatar
Do a search, this is a very common issue with BMW cars.
Old Dec 22, 2009 | 03:05 PM
05545i's Avatar
My Ride: 2005 545i Sport 6MT
A similar tick happened to mine, the waterpump was shot. Try grabbing the water pump pulley and moving it up and down. If there is play, thats more than likely the noise you are hearing. It requires replacement.
Old Dec 22, 2009 | 03:21 PM
billeul's Avatar
yes, it gets lou
