stock boost on turbo 08 535i?
7-9psi depending on weather and elevation...
as the boost goes up, timing and fuel pressures also needs to be controlled to prevent knock events or limp codes/over heating the turbos....
the jb+ which attaches to the tmap sensor, none of the mentioned controls above with it, raise boost to 10-13 psi IIRC.
with the jb3 and other ecu tunes, the boost has been noted to go as high as +17 psi IIRC on 335's (depending on maps, i think jb3 v2 has been reported to even hit 18 psi)
I think on on flashes (GIAC, ESS, etc..) boost has been logged on their S1's to be 13-15 psi's IIRC....
ecu and flashes are safer on the turbos as fuel pressures and timing is controlled better....
in terms of safety: Flash>piggyback IMO
***obviously with the higher psi's you'd like to have better bolt-on aftermarket parts to help such as an FMIC (not available for 535's), DP's, and better flowing exhaust systems...
***more info and research can be done/found on n54tech.com or e90posts: the FI section
Dinan which comes with a 50000 mile 48 month warranty maxes out at 13.0 from the stock 8.8 psi
