My 05 545 has a hard brake pedal. Its like stepping on a brick. It moves a certain distance then no more movement and the car has not stopped completely. According to my I-Drive I had 3500 miles left on my front pads so I had both front and rear replaced. No improvement.
Any sugestions? |
I had the same problem. The brake vacuum pump is probably broken. Take it to the dealer. :)
Michael Acute Performance
Any sugestions? |
I would agree with Smelly Feet, or you may have glazed your pads, have you been braking hard from high speed regularly ?
Michael Acute Performance |
I don't sorry.
Originally Posted by kxmills' post='894136' date='May 29 2009, 10:42 AM
Would you happen to have a part number?
I recently had this same problem, and after I visited a few shops I was informed my brake booster went out. Rudy was generous enough to create a TIS file on how to replace the brake booster, as well as a few other components (brake fluid reservoir, master cylinder). Here is the link to that document:
https://5series.net/forums/index.php?autoco...i&img=17568 Also, here is a link to a website where you can purchase the brake booster for a 545i: http://www.partsgeek.com/gbproducts/YN/E17...eek+Google+Base The mechanic said the OEM booster is basically a pump to assist in heavy breaking, and that the OEM booster just wasn't strong enough. He used a TRW booster, which he said was well made and strong enough to handle the toughest braking situations. |
UPDATE: I had my local BMW mechanic replace the brake booster and bleed the brakes. Everything is running fine now.
| All times are GMT -8. The time now is 04:01 AM. |
