"Sticky" SAT
Dear All,
I have a new E61 530D with the Sports Auto Transmission, there are only 750 miles on the clock so far, but I have noticed an annoying issue:
Sometimes, the transmission lever will not move directly from D to R - for example when making a three point turn or during a parking maneuver it will stick in D - even though I press the button on the side of the stick. If I hit the P button and then move the lever to D then R, it's fine, but it will just refuse to go from D to R......... sometimes it will only let me move it from D to R if the car is at a dead stop........and sometimes, it's fine!
has anybody seen this kind of "stickiness" with the lever before - ad if so is it something that is likely to go away as I get a few more miles on it?
I presume this is an issue with the lever itself as opposed to the transmission - isn't the level only coupled electronically to the tranny as opposed to directly mechanically ?
Other than that, the SAT is a fantastic transmission.
My Ride: G30 M550i
Model Year: 2018
Clearly if the car thinks it's in motion, it's not going to allow you to shift directly from D to R. If you're at a standstill and it still doesn't shift, it might be that you're not depressing the brake pedal (again, I don't think it will let you shift into a drive gear (forward or reverse) without your foot on the brake.)
That said, I do think there are times when it doesn't shift if you do it too quickly...
I'll have to check my behaviour with the brake pedal - but as far as I know, every time I try to shift into reverse, my foot is firmly on the brake. It's the kind of scenario where you approach a single lane, humpback bridge and there's a car coming the other way so you want to reverse back a bit to let him through.......that's when the damn thing sometimes refuses to go into reverse unless i go to P first.
I'm going to give it another 100 miles or so to see if it loosens up....if not, it's going to the dealer.
bestofthebest
Mar 28, 2016 02:47 PM
bestofthebest
Jan 5, 2016 07:47 PM
PelicanParts.com
Meet & Greet Discussion
Oct 16, 2015 03:07 PM
biz77
Aug 2, 2015 04:10 PM
