stereo AUX input
Old Aug 2, 2006 | 05:05 PM
datkmai's Avatar
Hi, I am thinking of adding a DVD to the system to watch movies and have the sound to the AUX of the E60 sound system, but is there an AUX in the rear of a standard E60 system for me to do that?
Thanks for helping out
Old Aug 2, 2006 | 05:33 PM
Heiss5's Avatar
I believe the newer E60's have an AUX input below the rear center vents, or maybe that's the new E90's. I'm assuming your E60 does not have this because you would be able to see it. Either way, you could run your normal dash AUX input pretty close to the same area and then just use an RCA cable to get you the rest of the way. Or you could just run the audio cables from your DVD player all the way up and into your dash. It's pretty easy to take apart the center console, dash, glovebox, seats, and door molding on the E60, so you should be able to run concealed wires anywhere you want. Hope that helps.
Old Aug 2, 2006 | 05:36 PM
bmw4life's Avatar
My Ride: Look At My Signature. -Other Rides and Previous Rides: 04 BMW X3 | 03 BMW 330i (Sold) | 05 BMW M3 (Gone)- 05 Infiniti G35 sedan, Premium Package, Bose Sound, HID, Sports Package, Hardwired Escort Passport x50 Blue Installed, New Transmission Installed, Navigation, Keyless Entry+Start Other Current Ride.
07's have a aux port in the back on the center console between the two cig adapters
Old Aug 2, 2006 | 06:32 PM
525iSE's Avatar
You can also just ask your dealer to retrofit the AUX at the back and order the new console under the vent. I think its much better than running wires from back to front since it requires a lot of taking apart your car in order to have it all concealed. Peace..
Old Aug 2, 2006 | 08:24 PM
EBMCS03's Avatar
For the E60 2007 cars have them. and yes it is in the back of the center console. You should be abel to see it if you are sittin in the back seat... if you dont see it or you dont have a 2007 then you'll have to get it retrofitted at the dealer. Thats probably even better for you then you can have the dealer run it inside of the glove box or wherever you want it rather than in the rear center console... I think thats a bad place for it.
Old Aug 2, 2006 | 08:38 PM
my530i's Avatar
Do you think best place would be center console armrest storage? IS has it there.
Glove box location is good for this kind of mod.
CHRGRS_BMW
38
Sep 1, 2016 09:39 AM
bestofthebest
Mar 28, 2016 02:47 PM
Jiawei Zhao
Oct 21, 2015 08:46 PM
545i-pilot
Sep 29, 2015 08:33 AM
Kaane
Sep 6, 2015 04:01 PM
