steering wheel vibration
My Ride: 2006 550i sport pak. all the other goodies..
MODS: M5 front, sides, aFe throttle body spacer, RPI Red scoop, amber angle eyes, powder coated sport rims, tinted tail lights. smoked side blinkers, color of car and rims roundels, real carbon fiber roof spoiler, 550i number flat black, LED license plate lights, MTX 12' sub, dyno mat, tinted Windows, flat black grill, flat black exhaust tips, light smoke headlight tint, foged out eyelash, velocity booster.
Warped rotors cause the steering wheel to vibrate while stoping; Not to sure why it would do it while your driving. ^^^ what they said sounds about right.
My Ride: Bmw e60 530i _-_ professional navigation- mystic blue exterior- beige interior-logic7-18 inch rims-active steering-bluetooth-adaptive xenon lights-sunroof-sport steering wheel-comfort seats-tv-pdc
Thanks all for the reply, appriciate it.
I'm considering changing my lower control arms asap.
My Ride: 08 528i
I recently replaced my front rotors and pads and it cleared a slight vibration while braking in the higher speeds, if going 60-80 mph, the first initial contact of the brakes would make my steering wheel vibrate - gone now.
My Ride: E60 530dA 3/2004
Have You allready solved the problem? What was it?
I tested yesterday a 530dAT with roughly 240 tkm in odometer. The car was surprisengly good, hard to tell any difference to my earlier E60's which had rougly 100 tkm less driven, but:
That tested had one problem with the steering (servotronic, not active):
When turning wheels stationary or at a low speeds, everything worked perfectly well. But in speed of 70 - 80 km/h, steering wheel started to vibrating and it got much worse when turning, even a bit. I think I know how it feels when tyres are out of balance, but I was not sure about this. I got a feel that the problem is in servo pump. Maybe the same reason that in Your case.
If the endlinks would go bad, than you would hear cling going over some potholes right? In my car, driving about 100km/h when i accelerate I Can feel little vibration, and that's only time whe i can feel it...I was thinking it might be bushings???
Guys I replaced my lower control arms in the dealer, some of the vibration is gone but some is still their I have a front shock leaking oil I have been adviced to change it as that might be the problem, but I don't think a shock would do that, I also have been adviced to make a road force balance that my solve the problem.
TexaZ3
05-06-2015 09:54 AM
