Steering wheel tilt not working
Old Feb 11, 2013 | 03:31 PM
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
Default Steering wheel tilt not working
So a couple days ago my steering tilt completely stopped working. I can no longer move the steering wheel down or let alone up. It's stuck in the up position. Prior to it completely not working it made a grinding noise twice then all of a sudden it stopped working.
I decided to take it the stealership this morning. I was hoping that it was just the steering electronic motor adjustment gone bad. The stealership tells me I have to replace the whole steering column !!!!! No way I'm going to pony up $2200 for this.
If the steering tilt was stuck all the way down I could care less but it's stuck all the way up!! It feels like I'm driving a damn bus. It feels so uncomfortable.
Does anyone know if I can manually bring the tilt down? I don't care if it doesn't go up again.
Old Feb 23, 2013 | 07:32 AM
greentrbo95gst's Avatar
Just use these for driving.....
Old Feb 23, 2013 | 08:16 AM
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
lol no comment
Old Feb 23, 2013 | 09:46 PM
Gee_115's Avatar
My Ride: 07 550i Sports Package
I'm about to install a used Steering column, I got the entire column for about $150 steering wheel included. This could be an option for you. I've been kinda busy so I haven't gotten a chance to replace it yet. I will report back when done.
Old Feb 24, 2013 | 04:43 PM
AchtungE60's Avatar
My Ride: E60 530i
Unplug the electrical contacts and plug them back in. Check fuses. Dealers just replace on your pocket...even if there isn't a "real" problem
Old Feb 25, 2013 | 07:43 AM
pradden's Avatar
My Ride: 02/2006 525i Titanium Silver Metallic Manual 6-Speed
I had this exact same problem happen to me. They first replaced the motor, but that didn't fix it, so they ended up replacing the entire steering column. Over $2K, but it was covered under my CPO.
Old Feb 25, 2013 | 09:11 AM
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
Thanks but I ended up paying the dealership $$$ to remove the steering column and adjust it manually. Now it permanently is all the way down . Let us know how your install goes. Maybe down the line I can get a used one as well.
Old Feb 25, 2013 | 09:16 AM
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
I checked fuses everything was in working order. The problem is the actual steering column and adjuster motor. For now I asked the dealer to adjust it manually, maybe in the future I'll get this fixed.
Old Feb 25, 2013 | 09:17 AM
b00sted415's Avatar
My Ride: BMW E60 M5
Model Year: 2010
Engine: S85
Yeah most of the people that had this problem got it fixed under CPO.
Old Feb 25, 2013 | 10:01 AM
H F's Avatar
H F
My Ride: 2005 545
I had the steering column replaced under waranty . but my new column (3 yrs old now) made a sqeeking noise.. but getting to The point as i was greasing the column i was moving it up and down. Then.. it stoppeed workin.. I was like oh shit !! thought i burned the motor. but after a few minutes it reset then all was good...Maybe u need to grease the column cause the original grease is dried out .. possibly putting strain on the motor as its goen up and down...and its getting hot.. Did the column ever reset after letting it sit for a bit... ??
