5Series.net - Forums
-   -   Steering wheel squeaks upon start-up (https://5series.net/forums/e60-discussion-2/steering-wheel-squeaks-upon-start-up-85711/)
mbp727 Sep 16, 2009 02:07 PM
So as you all know, when you turn the key in the ignition, our steering wheels move either up/down in/out to our specified settings and then return to the rest position when the key is removed. More times then not, my steering wheel will squeak and I'm wondering how to fix this? Will a spray of wd-40 do the trick or is there something else you would recommend? Thanks in advance.
