Steering Wheel positioning
Old Jul 4, 2005 | 09:16 AM
Matrim604's Avatar
My Ride: Sapphire black 545i with sports package, premium package, 6 speed manual, 20" Maya rims.
Just a little quirk i've noticed... Does anybody find that after you start your car and the steering wheel returns down to its programmed position, that it is sometimes a little off? It only happens to me maybe once out of ten times, but when it happens the return position is off by about 1 centimeter (sometimes less). To correct it all I have to do is push my seat memory button and it'll return to the proper position. Anybody else have this happen ever?
Old Jul 4, 2005 | 09:21 AM
my530i's Avatar
I have the exact problem and I don't know how to fix it. The only way to fix it is to push the memory button. Bummer, Bimmer!
Old Jul 18, 2005 | 09:17 PM
rduncan's Avatar
Unhappy
Originally Posted by Matrim604' date='Jul 4 2005, 11:16 AM
Just a little quirk i've noticed...? Does anybody find that after you start your car and the steering wheel returns down to its programmed position, that it is sometimes a little off?? It only happens to me maybe once out of ten times, but when it happens the return position is off by about 1 centimeter (sometimes less).? To correct it all I have to do is push my seat memory button and it'll return to the proper position.? Anybody else have this happen ever?
[snapback]145731[/snapback]
My situation is a bit different, I think: my steering wheel always returns to the same position BUT not exactly where I left it. I find that I can manually move the steering wheel lower (vertically), perhaps another 1 cm or so. Then when I restart, the wheel moves back (a bit higher than before). Is that weird or what? Obvoiusly, I like the steering wheel low (so that I can read some of the speedo over the top of the rim).
Robert
Old Jul 18, 2005 | 09:23 PM
EBMCS03's Avatar
Hummm I thought it was a side effect for using two keys and two memory options...
Old Jul 18, 2005 | 09:32 PM
rduncan's Avatar
Originally Posted by EBMCS03' date='Jul 18 2005, 11:23 PM
Hummm I thought it was a side effect for using two keys and two memory options...?
[snapback]150557[/snapback]
Not for me - I am the only driver and only use one key. And the situation occurs exactly the same for me, time after time. Is it the same for you, too?
Robert
Old Jul 18, 2005 | 09:43 PM
EBMCS03's Avatar
Originally Posted by rduncan' date='Jul 18 2005, 10:32 PM
[quote name='EBMCS03' date='Jul 18 2005, 11:23 PM']Hummm I thought it was a side effect for using two keys and two memory options...?
Robert
[snapback]150558[/snapback]
[/quote]
I'm not sure... i never really paied attention... but i know i had to re-adjust the steering wheel sometimes after switching drivers... and not all the time. so.
BUT there is a fix already... v18.x it states it already
http://forums.e60.net/index.php?showtopic=13746
Old Jul 18, 2005 | 09:47 PM
rodneyremington's Avatar
My Ride: 2005 545i with everything
Yes i have this same issue.
Old Jul 18, 2005 | 10:01 PM
DINAN530i's Avatar
Originally Posted by rodneyremington' date='Jul 19 2005, 12:47 AM
[quote name='Matrim604' date='Jul 4 2005, 10:16 AM']Just a little quirk i've noticed...? Does anybody find that after you start your car and the steering wheel returns down to its programmed position, that it is sometimes a little off?? It only happens to me maybe once out of ten times, but when it happens the return position is off by about 1 centimeter (sometimes less).? To correct it all I have to do is push my seat memory button and it'll return to the proper position.? Anybody else have this happen ever?
[snapback]150563[/snapback]
[/quote]
i have the same issue however when i go to hit the memory it will not store the lower sterring setting i have to maunaly adjust it everytime, goes in tomorrow hope they fix this...
Kasmo
May 7, 2019 03:30 AM
TexaZ3
May 6, 2015 09:54 AM
Ki
Jan 27, 2004 03:53 AM
Jun 17, 2003 09:38 PM
