Steering Wheel Noise
Old Sep 21, 2009 | 11:53 AM
mag75's Avatar
While driving at highway speeds on rougher roads (not perfectly smooth, not crazy rough), I get an annoying sound coming from my steering wheel. I have narrowed down the source of the sound but dont know how to fix it...see the below picture, the sound seems to be coming from behind the plastic pieces that control the sound etc....more specifically diagram #4
Does anyone know how to fix this? Or had a similar problem. The sound is not very loud, but annoying. It sounds like something is loose, and just needs tightening.
If you havent had this problem, have you had experience removing these pieces? If so, how do I do this ?
Much appreciated.
Old Sep 21, 2009 | 03:36 PM
delje08's Avatar
My Ride: 545i
I have the same problem, and when you hold down the plastic piece noise goes away. It is annoying, can anyone help fix.
Old Sep 21, 2009 | 05:48 PM
mag75's Avatar
Yep. Exact same problem. My guess is we can replace those plastic pieces....before i go that route, I would like to see if anyone has ever removed those pieces...then maybe we can tighten or add something to prevent the noise...someone please help. Took me forever to find the source of the noise.
Old Sep 22, 2009 | 11:36 AM
Tinkerer007's Avatar
My wife just bought a used 2007.
I was taking a service guy for a ride to ask about a noise from the front of the car (turned out to be normal noise for runflat tires). He pointed out that the buttons on the steering wheel were buzzing. He said it is a common problem and had us bring it in to be replaced under warranty. He said the buttons wear out.
Old Sep 23, 2009 | 12:14 PM
Jonoballer's Avatar
I get that squeeky noise when I fully turn my wheel
Old Sep 23, 2009 | 03:26 PM
BET530's Avatar
My Ride: 2006 530i
i had the same problem, dealer told me it was the pieces that hold the buttons, they just preplace mine.
Old Sep 28, 2009 | 09:06 PM
bitboy's Avatar
My Ride: 530i 2006 Jet Black w/tan leather. Premium package; Sport Package; Sat Radio
I have the same issue. Has anyone found a solution to the steering wheel noise?
Old Sep 29, 2009 | 03:17 AM
delje08's Avatar
My Ride: 545i
im going to put dynamat on there and see if noise goes away.
Old Sep 29, 2009 | 03:52 AM
steve.r's Avatar
I had a squeeky steering wheel, but mainly at low speeds when turning a fair bit. The dealer put some sort of additive in the power steering reservoir/unit and its gone. Although, based on how you've described it probably a different squeek.
They said mine wasn't covered by warranty but did it as goodwill.
Old Sep 29, 2009 | 07:36 AM
mag75's Avatar
Good to hear. Cost? Or was yours covered under warranty. Thanks much.
