Steering wheel memory issue
I have memory seats and steering wheel. When I switch the car off, the wheel rises up and away to make getting out easy. Fire the car up and the wheel comes back to where you left it.
Except it doesn't. I like the wheel extended as far out as possible, and the memory function seems to forget to extend it the last centimetre or so. Sounds tiny, but it makes the difference between comfortable and not for me.
I've done a search and can see others have had the same problem, but I don't see what the fix may have been. Can anyone help?
So far the dealer has tried:
resetting the memories;
updating the car firmware to latest version;
pretending there is no problem.
I'm fed up with them claiming there is no fault every time I pick the car up, only for me to show them again how to reproduce it. Any hints on what they need to do? (other than stop scratching their arses).
Model Year: 2005
Engine: 545i
As suggested, try a different dealer.
Good luck.
TexaZ3
05-06-2015 09:54 AM
