Steering wheel allignment
Old Oct 31, 2004 | 03:16 AM
jmcaiado's Avatar
Thumbs up
Hi,
Yesterday i noticed that my steering wheel is not fully horizontal when driving in a staight way. (slightly twisted to the left)
What kind of calibration has to be done to fix it?
Old Oct 31, 2004 | 04:28 AM
gdavis's Avatar
With conventional cars, front-end alignment can often affect the steering wheel alignment. But with active steering, there may be additional issues. Maybe the dealer should investigate it for you...
Old Oct 31, 2004 | 05:45 AM
JDN's Avatar
JDN
One of the notations made on my work order this week with the software upgrade to 13.3 was "Drive and reset steering angle sensor." Have no idea what that involved, but would surmise it to be after the fact settings by the dealer.
Old Nov 1, 2004 | 08:45 AM
John W's Avatar
Rudy posted the steering angle calibration procedure the other day, for use after disconnecting the battery. Search for threads on auto-dimming mirrors - that was the topic.
Old Nov 3, 2004 | 09:36 AM
jmcaiado's Avatar
Thanks for the replyes.
The problem was solved free of charge at the dealer.
The car had to be connected to a terminal to solve the calibration issue.
Old Nov 3, 2004 | 09:39 AM
Francois's Avatar
Hi today I had an upgrade to V13.3 and it seems to me that at low speeds turning the streering wheel is heavier. I have Active Front Steering. Anybody else did notice this after a sw upgrade?
Old Nov 3, 2004 | 09:43 AM
jmcaiado's Avatar
[snapback]52400[/snapback]
Yes, it's heavier. But it's ok because, before it was too light for my taste.
Old Nov 3, 2004 | 09:49 AM
Francois's Avatar
Hi jmcaiado, did you allready have the time to look for the ordernumber for voicecontrol ? See other post
Old Nov 3, 2004 | 09:57 AM
jmcaiado's Avatar
[snapback]52404[/snapback]
Ok.
Here's the code that apperars on the invoice: 01 39 0 393 654
Old Nov 3, 2004 | 09:59 AM
Hormazd's Avatar
Heavier than older SW versions but not heavier than V13.2 or a couple of revs prior. I prefer it.
