5Series.net - Forums
-   -   Steering wheel adjustment not working. (https://5series.net/forums/e60-discussion-2/steering-wheel-adjustment-not-working-145627/)
TheRedStig Sep 11, 2016 07:27 AM
Good day fellow BMW owners. Long time lurker, first time poster.
I have an 08' 535i with 135k on the clock.
About a month ago i had what smelled like a fuse burn out behind the steering wheel. Since then the wheel hasn't moved at all. I saw smoke for a few moments and after being sure there wasn't a fire I've been driving it and there have been no symptomatic changes.
1. Power seats still work fine.
2. If it's a fuse then it's one I've not learned of. I've checked the couple behind the glove box i know to check.
3. When you press the button in any direction you can hear the faintest noise for just a split second like there's power to the switch but i can't confirm there is for sure.
What would you try next?
rice_rocket88 Sep 12, 2016 01:01 PM
Sounds like your motor got jammed.. if you can actually hear something when you push the button then either the motor itself is dead (although I doubt you'd hear it click) Or the mechanism isn't working. Someone had a thread about unjamming it. I myself have mine just stop working, no power.. no idea :) Thankfully the wheel is in a good place for me so I have forgotten about it.
TheRedStig Sep 12, 2016 08:45 PM
Good evening. Awesome. I can work with that. Any idea how to get that lower cowling off the bottom of the steering wheel?
