Steering Problem
Banned
Got my car back from aux input install--working great--highly recommended. That's the good news.
Bad news is on the highway I noticed that my steering wheel is off center, to the left, by 5 - 10 degrees. Car drives straight, doesn't pull in either direction, just that the steering wheel is off center. I seem to recall others had this problem after new CIP--they upgraded mine to 17.01. Made an appointment. Is this just a matter of resetting the AS? Is it just reinstalling the software?
Originally Posted by stream' date='Jun 11 2005, 07:29 PM
Got my car back from aux input install--working great--highly recommended.? That's the good news.
Bad news is on the highway I noticed that my steering wheel is off center, to the left, by 5 - 10 degrees.? Car drives straight, doesn't pull in either direction, just that the steering wheel is off center.? I seem to recall others had this problem after new CIP--they upgraded mine to 17.01.? Made an appointment.? Is this just a matter of resetting the AS?? Is it just reinstalling the software?
[snapback]138673[/snapback]
Start the car. turn steering wheel clockwise to full lock then anticlockwise to full lock then back to center and turn off the car. The start the car and test.
Originally Posted by Hormazd' date='Jun 11 2005, 10:13 PM
The AS just needs to be reset.? But before you make an appointment try this:
Start the car.? turn steering wheel clockwise to full lock then anticlockwise to full lock then back to center and turn off the car.? The start the car and test.
[snapback]138700[/snapback]
I thought it was turn left all the way first, and then turn right all the way, and then back to the center; then restart car.
Either way try both methods...
Banned
Is this a relatively quick procedure (i.e., can they do it while I wait) or is it like updating the software (which could "only" take a few hours, or possible a lot longer if problems)?
[snapback]138772[/snapback]
They may try to say they don'y know whats wrong and try to make it lomger but you should make clear it was right when u went in and wrong when u came out of software upgrade. It IS the reset u need.
Banned
Thanks for the info--I'm going to tell them I just want to wait while they reset the AS.
My Ride: 2011 535i space gray/black, 6sp manual, ZSP, DHP, Prem, Prem2, split-fold rear seats
SOLD: 2008 550i sport, 6sp manual, Carbon Black/Black, Active Steering, NAV, CWP, Heated and Folding Rear Seats, PDC, Logic 7, IPOD, Bluetooth
SOLD: 2004 545i sport, 6sp manual, 3/04 build date, Saphire Black/Beige, NAV, CWP, Heated and Folding Rear Seats, PDC, Logic 7, Bluetooth
Exactly the same thing happened to me. I had my 545i software upgraded to version 17.?? and the steering wheel is off. It's in about 12:30 position when driving straight. I'm going back tomorrow morning. It's supposed to take 20 minutes to reset.
