Steering Problem
Old Oct 5, 2010 | 08:08 PM
BulldogE60's Avatar
Hey guys/gals, need your help here to diagnose my steering problem. Everytime I make a wide turn my engine makes a weird whining noise and the steering wheel starts to vibrate. If I take the turns at a very slow speed I will not have the problem, but at normal speeds it will occur.
Now let me specify the wide turns. Typically they are right handers. I am not referring to simply making a right turn from one street to another, but rather a freeway off ramp or off ramp that has wide turns that suddenly tightens (does that make sense?).
If I turn the car off for about 5 minutes, it'll go away after start up. Some have said it can be the power steering and maybe the fluid is low (idrive does not mention anything) I am hoping it is just that simple, but I have a feeling it is not. Anybody have any ideas?
Old Oct 5, 2010 | 08:34 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
maybe your front wheel bearings are worn. does the whine change with vehicle speed, or engine speed?
Old Oct 5, 2010 | 08:55 PM
dawid_w's Avatar
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
But did you check the level of the power steering fluid? What color is it? Do you have active steering and\or dynamic drive?
How many miles on the car?
Old Oct 6, 2010 | 05:51 AM
BulldogE60's Avatar
Turbo: Yes it does change with rpm/engine speed, I have a manual so as I get out of first gear it gets louder then quiets down. If this is the case, is it real expensive to change?
Dawid: I have not checked the power steering fluid. How do I check it? Active steering/Dynamic drive if that is in the sport package, I do not have it. Car currently has 50,400 miles.
Old Oct 6, 2010 | 05:13 PM
dawid_w's Avatar
To check the fluid ? open the reservoir (see the pix) and check the level and condition of the fluid (color).
I would also recomend this manual. Very helpful in troubleshooting.
Amazon Amazon
Old Oct 6, 2010 | 05:23 PM
turboawd's Avatar
if the noise is directly related to engine rpm, then it sounds like a power steering pump, but you say it makes no noise when turning slow?? how about if you are parked or rolling along slowly and try turning the steering wheel real fast, does it make noise then? try again with elevated rpms.
does your car have active roll system?
Old Oct 6, 2010 | 07:57 PM
BulldogE60's Avatar
Thanks Dawid.
So I just realize it happens at slow speed as well. I leaving a parking structure parked on the 4th floor and after turning from 4th to 3rd floor I got the annoying sound again. If it is the steering pump, is this covered under warranty? I'm still under CPO. Also, I do not have Active roll.
jfmartin25
Nov 2, 2022 01:42 AM
Kasmo
May 7, 2019 03:30 AM
shervinj
May 8, 2015 09:03 PM
DC5Series
May 3, 2015 09:15 AM
rayc
Sep 21, 2004 03:07 AM
