5Series.net - Forums
-   -   Steering module failed - HELP! (https://5series.net/forums/e60-discussion-2/steering-module-failed-help-149939/)
ripley Aug 22, 2019 02:44 AM
Hi all.
2007 530D LCI
Couple of weeks ago I did the following work
  • Disconnect battery
  • Change engine mounts
  • Disconnect steering column from rack and push up and out of the way (after I disconnected the battery I had to move the steering column by pushing on the front wheel to get spanner access to a bolt).
  • Remove turbo for a look over (bit low power but turbo seems OK)
  • Reassemble
  • Connect battery
  • Start
Since then I have active steering error - ISTA cannot communicate (much) with the AL module.
ISTA can sort of talk to the module to read/clear codes but it cannot perform the steering motor angle calibration. Keeps saying communication not possible. I don't mean the steering angle sensor - that is OK.
Battery is tested and looks good.
So I have no DSC, active steering or ABS.
Anybody heard of this kind of thing happening.
Seems incredibly coincidental but I didn't disconnect any steering related plugs anywhere. Maybe raising the motor did something.
Completely at a loss - hoping not to remove module if I can help it.
