Steering fluid question
My Ride: 2005 545i
Sport Package/ Step/Orient Blue/ Anthracite Interior/ Navigation/ Cold Weather Package/ Logic 7/Sirius/ Fold down Rear Seats/ Power Rear Shades/ Xenon Adaptive Headlights/ 6000k Fog lights/ LED Angel Eyes/ LED interior/Smoked LED Side Signals/ Shadow Grill/ Shadow line Trim/ Shadow Matte Black Badges
Is this the right fluid? I got it from the dealer.
My Ride: 2005 545i
Sorry, the picture did not upload. The dealer gave me a Valvoline DEX/MERC Automatic Transmission Fluid but in the reservoir it says use CHF 11S oil only. Is this the correct fluid? Thanks!
DO NOT pour that trans fluid in that PS reservoir.
If the reservoir says CHF 11S, then you MUST use that. Return that trans fluid and get a liter of CHF 11S.
Typically, parts guys ask what's written on the reservoir cap because some cars use trans fluid while others use CHF 11S.
My Ride: 2005 545i
PCY, thank you!
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
I am not sure if every e60 uses hydronic fluid for power steering system like CHF 11S but it should be written on power steering reservoir. I have active steering and my PS reservoir has CHF 11S written on it.
Like others members say check you PS reservoir and make sure before you put anything in there. It so easy.
My Ride: 2014 535 Alpine White
Do you messure the power steering fluid with the car running or with the car off? Mine is low with the car off so i was going to add some if this is the correct method.
My Ride: BMW
You don't measure if the car is running or not. You measure based on if the fluid is hot or cold. I believe there are markings depending on the fluid temperature.
