what is this State inspection? its due the month "after" my maintenance is over... Is this the smog check that the state requires? That usually comes in the mail and not the dumb iDrive telling me.
if you dont have inspections in your area, you can reset it yourself. it resets the same way the oil service is reset, so search for that.
Thank you. I have not tried it yet or went to verify but I assume its this... Posting it here for future reference.
Direction to reset Brakes, Oil, Microfilter, etc... "Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu). Now you are ready to go through the reset steps as follows: 1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car. 2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon. 3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu). 4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window. 5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on. 6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear. 7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above). Hints & Tips Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears. If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again). Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again). Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost"." https://5series.net/forums/topic/771...49#entry880549 AND here https://5series.net/forums/topic/111...st__p__1327434 |
Originally Posted by EBMCS03
(Post 1334488)
(Post 1334488)
Once the warranty is over, the service interval doubles for me LOL
Originally Posted by tooltec
(Post 1334521)
You do not have to use the service reset procedure to alter the date for that inspection.Just select it in iDrive service information and change the date .
THanks! |
Yes, you can simply change the date to what ever you want it to be. I use mine for mid oil change reminder as I just can't wait as long as its recommended to change the oil...
| All times are GMT -8. The time now is 06:10 AM. |
