Starts, Sputters, Dies within 5 secs
Old Aug 22, 2018 | 05:54 AM
ifarted's Avatar
My Ride: 08 535i
Default Starts, Sputters, Dies within 5 secs
My car died on me couple days ago, had to get it towed.
The car would start up fine, but would die right away. If i start it up and give it gas, the car would still die while giving it gas.
I am able to start it up, quickly put it in drive or reverse, and go for about 3-5 seconds before it shutoff on me and goes into neutral mode.
I have 1/2 tank of gas, its a 08 535i. No check engine light or codes thrown, i tried using the carly obd reader.
Old Aug 22, 2018 | 06:06 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
Did you do anything to the car just prior to the problem occurring?
Old Aug 22, 2018 | 07:04 AM
ifarted's Avatar
My Ride: 08 535i
Nope. Was driving, heard a bang and a min later car stalled at a red light.
Old Aug 22, 2018 | 09:13 AM
NoQuarter's Avatar
Engine: N54
What do you mean "shut off"? After the engine died, you had no dash lights, no radio, etc?
OR everything worked correctly other than the engine stopped running?
Can you do the 5 sec test over and over?
OR once it stops running, it won't start again for a while?
Old Aug 22, 2018 | 02:23 PM
ifarted's Avatar
My Ride: 08 535i
When i mean shut off, the engine dies but radio, lights and everything still runs.
After it dies i can turn it on and drive for 5 sec, and keep repeating
Old Aug 22, 2018 | 06:38 PM
E60Japanese's Avatar
My Ride: E60 2006 sedan auto
It sounds like your air intake sensor that is just after your air filter
It happened to me exactly as you have mentioned
Old Aug 22, 2018 | 06:53 PM
ifarted's Avatar
My Ride: 08 535i
The MAF sensor?
i pulled it out and try cleaning with brake cleaner. No changes
Old Aug 23, 2018 | 03:36 AM
Yes the MAF sensor
Do you have a friend with a
BMW that you can try his?
Old Aug 23, 2018 | 03:20 PM
ripley's Avatar
My Ride: 2007 E60 530d
Engine: M57
Will it run with the MAF disconnected?
Old Aug 23, 2018 | 06:11 PM
ifarted's Avatar
My Ride: 08 535i
No it does the same even when i disconnect the MAF sensor
