SRS AIRBAG 93F8 fault
Hi guys!I bought damaged 2006 530D. Unfortunately both airbags and tensioners have been deployed but it is all done now.I've replaced all bits needed (I hope) and can drive the car as it passed MoT.Thing is I still have a airbag/seatbelt warning light on dash and iDrive screen.I replaced the airbags and 2 tensioners and sent the airbag ecu to remove crash data and when I put everything back still had one fault 93F8 LIMIT FITTING TENSIONER DRIVER.Then I realized there is one more tensioner on the drivers seat.I replaced that too but fault didn't go.I've used INPA but can't clear the fault.Car drives perfect it's just that warning light and buzz when getting in and out of the car.Could You shed some light on this?Kind regards
Thanks Achtung for reply.I replaced the pax airbag as well or do You mean that someone switched it off?But why INPA says it's a driver side?
My Ride: 318d EE and 530d Ex Police car
i have same fault, search 93F8 to find my thread, resistence too high, drivers seat, swapped tensioner to original but same issue. can it be reprogrammed since erasing code only brings it back?
I fixed that ages ago. Completely forgot to post what was wrong. Well in my case I replaced both tensioner by the central console and the second one in drivers seat but didn't know the second one was faulty. Replaced with a good one, deleted faults and no problems since!
My Ride: BMW 5'er 520
I was there dealing with Airbags my self after listening to this noise when you switch car on for a year
I found out that there is a sensor under the seat and its all good but there is also a sensor of scales on my seats which are dead now and do not work. When I drive myself there is no mistake once its deleted once I drive with passenger errors jumps out as scales are broken on passenger side
