Squeeling brakes when backing up? Rear rotors have rust on them???
My Ride: 2004 530i stock.
2000 Jeep Wrangler non-stock =)
Well, I have noticed recently that my brakes squeel when i'm backing up, haven't really noticed while moving forward. It seems the more pressure i apply, the less they squeel. Also, I did notice that i have rust on the rear rotors, is that common for a BMW with 19k on it?
I thought the squeeling might be due to brake dust and recently had the car washed. The squeeling went away for a few days, but has returned. Do you think i should have the brakes checked or have the pads and rotors replaced. I really hate seeing rust on them in an form.
Also, when changing wheels, how is the tire pressure monitor affected? Is there a mechanism to attach to the new wheels or do the wheels have anything to do with it? Thanks fellas! =)
Nothing to attach. Just reset the FTM. FTM monitors the difference in speed between the wheels. When one wheel rotates about 12% faster than the others the warning will sound.
My Ride: Mini Cooper
about the rust I have it all the time if I leave it for a few days and not drive the car but the you drive it, the rust gose away. also my brakes have mice in them too, I am think changing them for EBC greenstuff pad & rotors. Itis very common for the OEM pad to have mice in them
My Ride: G30 M550i
Model Year: 2018
The brake squeal you're describing sounds like the brake pad wear sensor issue. It's very common and the dealer should be able to take care of it under a service bulletin.
zen is correct that FTM on a 2004 car is not dependent on the wheels or tires. The system shares the rotational sensors with the ABS/DSC systems. The newer cars (2006 I think?) have individual pressure sensors mounted in each wheel...
My Ride: Ordered: 2006 530i on Oct 1st, and due Mid Nov. 6 speed Manual, Navagation, Premium pkg, Sport pkg, Cold Weather pkg, Prem. Sound Package, Titanium Silver, Black Dakota Leather, Dark Poplar wood. 18" 7 Spoke wheels (style 123), euro reflectors, Sat Radio installed.
Originally Posted by Bubbarossa' post='342176' date='Oct 6 2006, 01:56 AM
As always, thanks for the replies! =)
Rudy...even my 2006 model, a car I bought Jan 2006, have the break squeel problem. been to the dealership for 2 visits, no fix yet....
It's more comon than you think, and they did not fix the issue with the new design.
My Ride: G30 M550i
Model Year: 2018
![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
Anyway, the fact that they redesigned the sensor, coupled with the fact that the new sensors were on back-order a few months ago is why I said the problem is very common.
you will need to champher ther peds.
For the rust, use "antiseize." It is sold in most auto supply stores. It is a lubricant that prevents future rust. It seemed to work very well.
I recently put it on my 2007 530i when rust started to form after 2 months. It worked well.
socale39
09-05-2023 08:30 AM
Awest91
09-17-2022 11:05 PM
