Squeecking steering wheel
My Ride: 2004 525dA E60 Safire Black Met.
![Angry](https://5series.net/forums/images/icons/icon8.gif)
During wet/cold weather when I have been driving for a while and turn my steering wheel
it makes this (low frequenz) squeecking sound.
This is very irritating, what can be the problem?
Andreas.
Andreas.
Originally Posted by my530i' post='394014' date='Feb 21 2007, 11:05 PM
Coil Spring Adapter could be the culprit.
Sinse the squeaking sound is nearby the steering wheel (inside the car) I
wonder about the origin of the problem, if it could be something else?
you see.. when I turn the steering wheel, I hear a whiny squeak. Not very loud,
and the kind of noise you might expect two pieces of rubber-ish material.
I?ve read (in this forum) that something on the steering column might need a bit
of lubrication, or that I have to change a plastic rubber on the steering wheel.
Could that be the problem? And is it expensive to fix? U see.. my warranty
went out last september!
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
I just had the whole steering column replaced by my dealer under warranty for the same reason.
They said it will also go away for a while with a new slip ring behind the steering wheel, but the only proper way is to do the steering column completely.
That's what they said and what they did. As it didn't cost me anything, I was ok with that and the problem is gone.
My Ride: 2004 5.30i Saphire Black on Auburn, Sports Pckg, Premium Pckg, Sound Pckg, HUD, Cold Weather Pckg, Heated Rear Seats, Electronic Rear Window Shade, Foldable Rear Seats with Ski Bag, European Reflectors, Active Steering, PDC, 19" AC Schnitzer Type II, Front: 245/35, Rear: 275/30 Toyo T1S, H&R Sports Springs, 35% Tinted Windows, B&B exhaust w/ custom straight pipe
I've been hearing this "clunk" sound whenever I make a turn that is 45 degrees or more. It's not loud, but it can get annoying. At first I thought it was the stuff in my trunk shifting around, but I think its coming from the steering wheel. any of you guys know what the problem may be?
My Ride: #1: 2004 545i; 6-speed manual; Sport Package; Mystic Blue with a gray leather interior and Anthracite wood; CWP; Logic 7.
#2: 2010 535xi Touring; Automatic.
Is it the noise in this video?
http://forums.e60.net/index.php?s=&sho...st&p=399642
I am trying to find out who has had this and how it was fixed since every time I take it in they say can not duplicate.
Thanks,
Tom
Thanks,
Tom
My Ride: 2011 F10 535i -Brilliant Graphite/Oyster
2006 E5004matic- I must have been on drugs when I got this car
2004 545i Black Sapphire/Truffle Brown interior
I had identical thing happen 1.5 yearss ago, dealer changed the steering rack as it was deffective, noise never came back.
happened when I was turning right or left but also at around 45 degrees.
TexaZ3
05-06-2015 09:54 AM
