Squeaky seats?
well, i'll do you a favor and spend a few more minutes of my time with you because you're not worth more than that. You can bragg as much as you want for your "wish to have" list of cars. We don't really care. The only reason you are here in this forum is to learn something and then go back to your dealer to complain. Prime example is your last post where you blaim BMW about the injectors. Had it ever occur to you that the injectors are manufactured and tested by Bosch, Siemens or NTK and not BMW. However, in your mind is BMW's fault because this is all you want to see.
Most likely you have spent your life's savings to buy or lease (who cares) a BMW and all you do is to complain. Show the forum a constructive post of yours, if you have any other than "hijacking" other people's posts to complain.
In a sense you are so lucky because you will never get a brain tumor. That can only happen to people who have brains.....
Enough said. Case closed.
Does anyone out there have a good product to clean the door molding rubber to stop it from squeaking??
Chromedome
My Ride: 530d Touring, pro nav, Logic7, leather, 18 inch, steptronic
Originally Posted by cap217' post='463350' date='Aug 28 2007, 05:15 PM
Well I still do not have an answer from anyone.... One other has this problem, any solutions?
My Ride: May 2008 530D "M" package Exclusive line.
Hello,
I don't know if it could help here, but having experienced same kind of problems on E46 (4 years ago), the noise just disapeared after having moved (on dealer advice) the seat on its full range (fwd, aft, up, dwn).
Just try...
Just try...
My Ride: Bmw 530d 2004
Originally Posted by Etienne' post='463381' date='Aug 28 2007, 08:33 PM
Hello,
Just try...
Just try...
Chromedome,
I had similar on the driver's seat when it was at its highest setting. I lowered it a little and the squeak went away. if I raise it to its maximum again, it squeaks.
Good luck
Good luck
My Ride: My 1st was an '06 530xi, Titanium Silver w/ gray dakota leather, sport pkg. & Nav.
Now my 2nd is an '08 650i CP, Space Gray, Blk Dakota, Sprt. Auto, HUD, Sprt. Pkg., Prem. Sound, High Beam Ast. & Comfort Access
I have the same problem and it appears to come from the area of the seat bolster (driver's side) where my lift leg rests. I have had it to two different dealers and both advised that "the seat is performing within acceptable parameters" and they "could not reproduce" any unusual noise. I have the sport seats and the squeak did not start until the car was about a year old. I think to correct the problem myself I would have to remove the seat entirely and lubricate it inside.
I will just live with it I guess.
Site Founders
I deleted all of the utterly immature and irrelevant posts from this thread.
I'd appreciate it if we could keep it on topic.
