Squeaky Doors
Model Year: 2015
Engine: N55
Originally Posted by skyetripper' post='385779' date='Jan 31 2007, 01:32 PM
Anybody got any top tips for curing the squeaky door syndrome? I thought this would be a thing of the past with the e60 models, but apparently not.
Thanks
Thanks
having said that mine have been replaced twice.
It is generally thought that getting polish on the seals causes a problem, ensure any polish on them is cleaned off with a good solvent.
My Ride: 520d saloon, manual 6 ratios, olivin metallic, star spoke 122 alloys, delete boot badge, bi-xenon adaptive headlights including washers, graduated tinted windscreen, exterior and interior mirror auto dimming plus electric folding door mirrors, extended light package, dakota beige leather, dark poplar wood, electric seat adjustment including memory function, heated front seats, advanced climate control, velour floor mats, sliding front armrest, lumbar support for front seats.
Thanks
Thanks
Seems to be an official BMW fix for vehicles produced after Jan 2005. It does seem to work so far and the tape if of a good quality and well applied in that it took me a week before I noticed it when washing the car.
Attached is the BMW line on this problem, hope it helps:
SI B 51 02 05
Body Equipment December 2006
Technical Service
This Service Information bulletin supersedes S.I. B51 02 05 dated October 2006.
SUBJECT
Squeaking Noise From Door Frame Area While Driving
MODEL
E60, E61 (5 Series)
SITUATION
Some customers may complain of hearing squeaking or creaking noises coming from the door frame area when driving on rough roads.
CAUSE
Movement between the flocking material (felt-like material indicated by the arrows) on the upper door seal and the surrounding roof panel may produce squeaking or creaking noises.
These noises may be amplified by contamination or cleaner residue on the door opening.
CORRECTION
In case of a customer complaint, refer to the procedure outlined below to replace the seals with improved parts and/or apply the specified transparent Teflon tape.
The flocking material was changed in 01/2005 to an improved material with exceptional rigidity, strength, and low moisture absorption.
The new and improved parts may not have any unique identifying stamps or markings. Therefore, the production date should be used to identify the new seals.
Updated seals will have a date stamp on the back of the part reading later than January 3, 2005 (3.1.2005).
PROCEDURE
Depending on the status of the vehicle, perform the applicable procedure described below.
Vehicles produced up to 01/2005, first complaint:
Replace all 4 upper door seals with the improved parts.
Follow Repair Instruction RA 51 21 360 to replace the front upper door seals.
Follow Repair Instruction RA 51 22 360 to replace the rear upper door seals.
Thoroughly clean the upper door seal's mating surface on the body of the vehicle with a silicone remover such as 3M General Purpose Adhesive Cleaner or Wurth Silicone Remover.
Do not apply "Carbaflo" on these door seals.
Vehicles produced from 01/2005, and vehicles that have previously had the improved seals installed.
Thoroughly clean the upper door seal's flocking material, as well as the mating surface on the body of the vehicle with a silicone remover such as 3M General Purpose Adhesive Cleaner or Wurth Silicone Remover.
Apply a continuous length of Teflon tape
(PN 9 407 798) to the contact area of the flocking material (1) on the body of the vehicle.
The area where the tape should be applied to spans from the middle of the a-pillar to the rear-most point on the rear door opening as indicated by the arrows.
Notes:
The tape should be applied slowly and very carefully to avoid trapping air bubbles under the tape.
To eliminate visibility of the tape when the door is closed and ensure proper contact with the flocking surface, the upper edge of the tape (1) should line up evenly with the top of the door seal (2) for the entire length of the applied area.
The tape should be applied in its full width (16mm), not be cut down to a narrower width.
C. Vehicles produced up to 01/2005, which are in for a repeat complaint, and have the original seals installed
Replace all 4 upper door seals as per procedure A.
Apply Teflon tape as per procedure B.
PARTS INFORMATION
Part Number
Description
Quantity
51 21 7 057 507
Left front door seal
Right front door seal
Left rear door seal
Right rear door seal
Teflon adhesive tape
3M General Purpose Adhesive Cleaner may be used for this procedure.
For more information on this product, please visit http://www.3m.com/.
Wurth Silicone Remover may also be used for this procedure.
For more information on this product, please visit http://www.wurthusa.com/.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
An additional work allowance of 3 FRUs may be added for the surface preparation and installation of the Teflon tape to the body of the vehicle, claimed under labor operation 51 99 000.
[ Copyright ? 2006 BMW of North America, LLC ]
Thanks
Thanks
Do not wax the sealings nor use any silicone or solvants etc!
My Ride: 2003 x5 4.4
Leather cleaner wipes did the trick for me. its been 3 months and not much sqeaking has returned. i got this solution from searching the forums on this site.
"Thoroughly clean the upper door seal's flocking material, as well as the mating surface on the body of the vehicle with a silicone remover such as 3M General Purpose Adhesive Cleaner or Wurth Silicone Remover.
The area where the tape should be applied to spans from the middle of the a-pillar to the rear-most point on the rear door opening as indicated by the arrows."
Any ideas where to get the teflon tape??
Remember that the SIBs published on here are typically applicable to the US market and whilst they are great guidance, and acknowledgment by BMW that a problem exists, there may be local BMW policies as to why the fixes given in the SIBs are not applicable in other territories.
ABC
ABC
ABC
ABC
If anyone gets told otherwise by their dealer then I suggest they fight it hard as this issue is so well publicised it would be difficult for them to wriggle out of it, in whatever country (they are, after all, a global company!).
I would have thought it should be quite an embarrassment for BMW
![Ermm](https://5series.net/forums/images/smilies/imported/ermm.gif)
I might be imagining this but I thought I read somewhere that this also had been a problem on the E39!
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
