Alright so my breaks squeak when i press on them just a little, not putting the car to a full stop..The dealers said they dont need to be changed because i serviced the car not too long ago, what do you guys think might be the problem? i can see the hubs are rusting a little.
honestly OEM brakes always squeak. a number of customers have ordered pads with or without rotors not only because they needed changing but just to get rid of the squeaks/brake dust.
BMW brake squeak. :rolleyes:
There are several things to know in this respect, here're a few that I can think of off the top of my head: 1. Squeaking does NOT necessarily mean there is anything wrong with your brakes. As long as there is no evidence of warped rotors (no shaking under braking), just run your finger on the COLD rotor and feel if its relatively smooth - you want to be sure there are no grooves. But everyone's OEM brakes squeak. 2. You can get an aftermarket set of pads and avoid squeaking. Do be careful though, as there are reports that some of the a/m pads are best to be paired with a/m rotors, bc OEM rotors tend to warp, being of a softer alloy than a/m. Expect to spend about 500-800 dollars (plus labor) for a set of a/m rotors, pads and stainless steel brakes lines (might as well change them, if you'll be upgrading the rest). 3. I've heard of - though have never used it myself - of a special liquid that you can apply to the rotors and it - reportedly -relieves the squeaking for a while, but needs re-applying when it rains, etc. 4. I once complained to my dealer that the brakes are making a lot of noise and they shaved (or polished? I don't remeber...) the rotors - whatever they did, it didn't work for too long - started squeaking again same day I picked the car back up from the service. |
just drive 60mph and just press your brakepaddle really hard untill u stop, like an emergency stop, and now the squeeky noise is gone, it normally stays away for a month, but watch out if there aren't any people driving behind you :D
took mine to the dealer also, they replaced the rear pads and sensors. But they still squeak. Its annoying but its really not that bad, now vibration is a whole diff issue. |
Originally Posted by v_therussian' post='1043514' date='Oct 30 2009, 01:54 AM
This is called bedding the brakes and you should do a search on how to bed the brakes properly before you do something that may cause a warped rotor, if you want to do this. In my experience it is not a long-term fix though.
Try making some, SAFE, hard speed breaking's. The squek in small speeds and the rusty hubs is so very normal on E60's. |
I'm going to have to comment on several points:
There ya got it ... my 48 cents worth :rolleyes: |
| All times are GMT -8. The time now is 07:37 AM. |
