Sqeaking/Ticking Noise (rear drivers side wheel)
Good Morning Members,
I was wondering if anyone has ever come across the problem I am having.....
When I drive at slow speeds I can hear a squeaking/ticking noise coming from my rear drivers side wheel.
If you could image a coin or nail attached to my wheel, As I speed up the ticking speeds up
(and eventually disappears at speeds above 60 km/hr)
It almost sounds like the E-brake is caught ? Maybe my break sensor?
Anyone know what this could be?
Thanks in Advance!
Thanks in Advance!
Thanks in Advance!
Thanks in Advance!
Originally Posted by muzzy' post='585350' date='May 21 2008, 09:01 PM
i have the same exact problem and it's been driving me crazyyy!!
My Ride: 525
Originally Posted by Ricracing' post='585382' date='May 21 2008, 02:27 PM
You guys have stone (nail, screw) in the tire thread.
+1 on a stone or nail on the tread.
other than that you can start checking the things that get a lot more expensive...
2) pull the tire and check brake, rotor
3) check CV Joint/boot
far more likely to be #1, especially if you drive over gravel.
simple problem , simple fix
