Sport Drive (SD)
![Thumbs down](https://5series.net/forums/images/icons/icon13.gif)
Hey, what do you guys think of the Sport Drive mode on our automatics? I am used to driving manual (I had a 3 series for a while), and I finally went auto with my E60. I find that the Sport Drive function gives the car a little more pickup.
Does anyone else use the Sport Drive?
My Ride: 2007 530Xi - Navigation, Premium package, Steptronic.
My Ride: E61 530d Touring, May 2004
I often flick to SD if needing to make a quick exit from a junction or away from the lights, as there is a noticeable lag in D.
Rarely use cross country, as if in cruise mode use D and if in pace mode use the manual shift mode.
My Ride: 2004 550i - AS, SP, CWP, Nav, L7, Rear Sunshades, PDC, Comfort Seats
![Badbad](https://5series.net/forums/images/smilies/imported/badbad.gif)
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
yes there is more "pickup" in sport mode. i barely ever use it though. im always usually in manual mode. more fun in my opinion
plus i wanted a manual transmission to begin with..
Originally Posted by ExGMan' post='410597' date='Apr 5 2007, 09:07 PM
My only observations are that the Steptronic in the SD position...
ABC
DS is just a lil bit different from D, but it doesn't do me justice as i found that most of the times when cronering hard or powersliding or whatever the gearbox even in DS will change into a higher gear at the slimest lift off the accelerator. The software isn't doing it's math right since i'm pulling alot of latteral G when i do that (or at least much more than normal) and it shouldn't allow it to change into a higher gear.
The scenario is this and frankly i'm tired of having it (hence i use M mode when i really drive fast):
DS approach a corner at high-medium revs, get it to drift slightly while feathering the accelerator, lift off at some point--->gearbox changes into the next gear---> a very idiotic sensation as you would expect the revs to be like just 2 seconds before into highs and you now sit into lower revs with lower power than expected. It's like vrooooooooM and then VROOOOOM after you already mashed your foot into the kickdown sensor. It's weird and for sure looks and sounds dumb.
Conclusion: Wana drive fast? Use Manual mode.
My Ride: '05 530D Sport Auto plus bits.
On the new LCI box they also appear have remapped the throttle response in DS mode much like the Sport buttonin the M3. The only way I can describe it is that in normal mode 100% power is at 100% depression prior to the kick down notch. IN DS mode I reckon full power comes in at around 25%-40% throttle movement.
It certainly gets round the original lag problem and caught me out when I first flicked my new one onto Sport mode.
Fatlab
Fatlab
I had a 650i with Step before I bought the 550i for the wifey and I am sorry to say that I miss the Sport button on my old 650i dearly. There is a DS and Sport button on the 650i and while the DS works as it does on the 5-series, the Sport button just turns the 650i into a beast!
