Spinning so dangerously in the wet with DSC on?
My Ride: On Order, due in May - 2007MY 530D SE, Silver Grey, Black Dakota, Auto, Brushed aluminium shadowline,sports seats / wheel, hi fi speakers, mats, space saver wheel and a few more bits
I am new to rear wheel drive but managed to spin a 525d during a test drive in the wet (full throttle on a roundabout in 2nd gear - a bit wet, salesman terrified but I controlled I it OK). That was 4 months ago and I was driving in the wet today for the first time in my new 530 D with 271hp and 590Nm (ECU re-map).
I found it very easy to lose the back end when turning out of a bend and flooring it even when all the DTC DSC settings are on. Is it the RFT Bridgestones?, a problem with DSC / DTC?, or am I expecting too much bearing in mind the amount of torque I am putting down.
I quite enjoy it but get a bit embarresed if any cars or pedestrians see me
Or is it just something to do with rear wheel drive I am not used too
My Ride: 14th Oct 05 delivery, 525d SE Silver Grey, Black Dakota, Dark Poplar, Adaptive Xenon, Prof Radio, Prof Nav, 6 CD Changer, BT, Advanced A/C, Electric Seats, Heated Front Seats, Thru Load/Ski Bag
DSC/DTC are working
If you experiment a bit more, you will find out with the traction control systems switched on, you only have limited ability to spin before the electronics take over. Fun whilst being safe
Find a safe place to experiment and you will soon realise that the electronic systems are always working in the background.
If you are new to rear wheel drive, try a 1 day rally driving course. You will very quickly come to realise why people choose BMWs over other marques - the enjoyment of driving
DSC on the BMW will allow some wheel spin. It won't take as much control over the car as would a MB. It's the nature of the car. You'll get feedback and have a good idea of what's going on while still keeping safe.
My Ride: E60 530d Sport - Carbon Black, Black Dakota Leather, Media Pack (satnav, bluetooth, CD changer), heated font seats, through load
Try turning the DSC off, and then see what happens. Diesel torque, wet road, and no DSC is quite scary.
My Ride: 2010 523i. Alpine white, dakota leather, 8 speed auto, VDC, bluetooth, HID lights, parking sensors, sport seats, black window trim, tinted rear windows
1988 Ferrari 328 GTS, nero on rosso corsa.
1992 Mazda MX-5 / Miata
2009 Ford S-Max 2.5T
I have a smooth, wide and empty 90 degree turn on the way to work where I still regularly switch DSC off, go to manual, select 2nd and boot it mid corner
Przemek
My Ride: 04 525DSE Auto Olivin
Try a one days course with Ultimate Car Control ( www.ulitmatecarcontrol.com ). They will teach you about the dynamics of a vehicle and in particular how to maximise traction (and how to lose it
![Devil](https://5series.net/forums/images/smilies/imported/devil.gif)
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Be prepared wear out rubber and brake pads
The back end on my 530d is snap happy and I only have 500nm.
I remember your post about the test drive spin and it does sound like you need to get to grips with the handling.
Personally I find RWD safer and more progressive than FWD, when the back end slides you just ease of the gas and apply a bit of opposite lock to correct.
I think you need to play about on a track with the electronics off to understand the cars handling - which should make you safer on the road.
My Ride: E60 523i
silver, black leather , sunroof , bluetooth , pdc , M sports kit , Steptronic gear box , active stearing , active cruise control
I was going to post a the same thing i also span today in the rain i went around a corner slowly then floored it the
back just span outa control what fun O and dtc was completly off
