Speedometer Error
My Ride: '04 545i, Silver Gray-Black Dakota, Cold pkg, Prem. Sound, Sport pkg, Nav, Voice Activation
I used to own a 2002 M3 that had a speedometer error of about 5mph over the actual speed. I am curious if the E60 series has the same issue? Also, why doesn't BMW correct this defect? Thanks
My Ride: F02 LCI Individual
Model Year: 2013
It's not a defect!
The speedo shows a little more than you're actually doing to protect you from accidentally speeding.
No speedo in any car is correct, unless somebody has corrected it aftermarket...
Originally Posted by Iceman' post='331091' date='Sep 5 2006, 01:43 PM
It's not a defect!
I understand that the 5-Series is about 3-4 mph off actual speed at 60mph. You can check it with GPS.
Has anyone figured out the exact differences? This really sucks for leased cars because they deprive you of a lot of miles. Someone stated that the odometer does not read off the speedometer, but I am not sure that this information is right.
The advantage of going from 17" to 18" tires is that you reverse the effects of the speedometer problem (bigger diameter). Oddly enough, when you go from 17" to 19" tires, I was shown that the two sizes have nearly identical diameters (the low profile 19" creates a similiar overall diameter). There is a website that you can go to that shows speedomter changes with different size tires. Very interesting stuff.
Best.
Model Year: 2013
Yes, right.
And when you change the size of the rims you need to code the computer with it, so that there's no difference.
My Ride: 2010 523i. Alpine white, dakota leather, 8 speed auto, VDC, bluetooth, HID lights, parking sensors, sport seats, black window trim, tinted rear windows
1988 Ferrari 328 GTS, nero on rosso corsa.
1992 Mazda MX-5 / Miata
2009 Ford S-Max 2.5T
Originally Posted by monacobmw' post='331136' date='Sep 5 2006, 09:08 PM
Totally agreed here.
Przemek
My Ride: 530 2006
msport package, steptronic, pdc, mystik blue, grey dakota leather, sunroof, Bi-Xenon, heated rear seats, Hi-FI system, velour carpets
Yes, when my speedometer showed 260 km/h my Garmin GPS said 250 km/h.
My Ride: 535d Sport in Carbon Black / high gloss shadow line and beige leather / dark poplar with professional nav, bluetooth phone prep, CD changer, bi-xenon adaptive headlamps, servotronic steering, folding mirrors, heated comfort seats, TV, extended voice control and Logic 7 hifi.
There is no "exact" difference - every time your wheels make a revolution and lose a molecule of rubber, the delta will change ever so slightly.... so unless you're going to have a wheel-rotation based speedo that calibrates itself constantly, forget having it accurate.
My Ride: 535ixT � On Order: 2010 E61, Ordered 1/05, Est. Birth 3/09, Est. Delivery 4/09, Carbon Black, Cream Beige Dakota Leather, Steptronic, M-Sport Pkg., Type 135 18
Model Year: 2010
My '06 530xiT has 18" OEM wheels and 4 x 245/40-18 tires with approximately 7k miles on them.
I recently ran a check vs. a GPS: at 70 MPH - the GPS read 68 MPH - or about 2 mph optimistic.
However, when I check my auto's speed against those 25 . . . MPH speed check radars located by local cops about our towns, my speedometer checks out as a bout 4 MPH fast. Perhaps the local cops tune their radars to read 2 MPH slow???
When we drive from Colorado to Connecticut next week I plan to do a series of speedo vs. GPS checks over a range of speeds (30-to-90 in 10 MPH intervals) and will post same.
