Speed limiter
At first I thought you were talking about the speed limit set up through idrive, and mine just blinks to tell me I'm going over about 85 to 90, only hit that on the interstate. As for the electronically limited top speed I believe this provision in the vehicle?s engine management computer prevents the driver from exceeding a preset speed, typically by deactivating the spark or fuel injectors.
My Ride: 545i; Manual Shifter
Originally Posted by Merv the Derv' date='Oct 6 2005, 03:38 PM
sorry - heres the pic
[snapback]180565[/snapback]
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
My Ride: Collected Sept 2009 - BMW E90 M3, Silverstone II, Novillo Black leather, 19" M Double-Spoke alloys, High Beam Assist, Electronic Damper Control, Voice Control, PDC, USB, DAB, High Gloss Shadowline, Sliding armrest, Trim Finishing in aluminium grey.
Originally Posted by BetterMakeWay' date='Oct 7 2005, 09:55 AM
What's the difference bewtween common rail and pumpnozzles?
Any info is appreciated! how can u tell if an engine is one or the other?
bmw uses ?
bmw uses ?
[snapback]180779[/snapback]
The VW group developed and use their own 'Pumpe Duse' technology.
Volkswagen's Pumpe Duse or pump injectors also use a computer controlled solenoid to control injector opening and duration but there the similarity stops. Instead of one high pressure pump for the fuel system, each Pumpe Duse injector is its own high pressure pump.
One of the advantages the Pumpe Duse injection system has is the high pressure it operates at. It can operate at up to 30,000 PSI injection pressure as it only has to deal with each injector separately rather than over a longer 'common-rail'. This in theory provides finer atomisation of the fuel for high torque and power with low emissions and high fuel efficiency.
So, if u are driving anything from the VW camp (VW/Audi/Skoda/Seat/Have I left anything out) it'll be a PD system. Otherwise, I'd be 99.99% sure it will be common rail. Most of the automotive world seems to have joined the 'common-rail' camp, including BMW. Why? Not sure. Maybe licensing issues from VW.
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
My Ride: -04 530D
Originally Posted by BetterMakeWay' date='Oct 7 2005, 11:55 AM
[quote name='skaffa' date='Oct 6 2005, 08:45 PM']This is AFAIK:
In diesel electronics stop giving more fuel to the cylinder. In common rail and pumpnozzles system most probably shortening nozzle opening time. In old systems decreasing pump capacity.
In petrol either turning ignition later or just easing "pedal" in "fly by wire" systems.
If anyone know for sure, please tell us!
Skaffa
Skaffa
[snapback]180633[/snapback]
bmw uses ?
[/quote]BMW use common rail and VW use "pumpduse". Outside of the car it's almost impossible to say which is which. Common rail should be more quiet. Common rail nozzle is smaller.
Other things IrishEyes explaned better.
Skaffa
Yep! I got it! Thanx IrishEyes and skaffa!
Does any body know if the 110hp TDI engine has PD? Someone told me that the TDI 110bhp doesn't have it and only the 115HP upword engines have it!
Hi
Does anyone know the MPH per thousand revs in the gearing for the 535D as that may well answer why the limiter did not kick in as the car was not doing 155mph.
When we tested the cars with a prolaser the speedo was maybe 10% optimistic.
Cheers
Cheers
My Ride: -04 530D
Originally Posted by Knobjockey' date='Oct 8 2005, 06:12 PM
Hi
Cheers
Cheers
[snapback]181284[/snapback]
Skaffa
My Ride: -04 530D
Hi
Cheers
Cheers
Skaffa
bestofthebest
03-28-2016 02:47 PM
umnitza
09-02-2015 11:28 AM
