Spacers Size
My Ride: Titanum Grey 525i 2004
Black 328i 2008
2008 E70 X5
Hi all,
I have VMR V710 19" on my bmw 2004 525i. I put hub-centric rings but the car still vibrating when I drive. I believe I need to get spacers but I dont kon what size fits. Do you guys know what is the difference between the 12mm, 20mm etc.?
if u could tell me the right size I would really appreciate that
btw the exact wheels size I have are:
19*9.5 ET 22 for rear
19*8.5 ET 20 for front
Thank you
Thank you
Hi all,
Thank you
Thank you
Black 328i 2008
2008 E70 X5
no I didnt I bought the rims from a local guy who had only the rims without the rings that should come with wheels i guess
was it from a business or a private seller? did you inspect for small cracks, etc? these wheels have been known to crack which could in fact cause vibration.
what type of hub rings did you install (brand and material)? Are you sure they are the correct size?
Spacers would not remedy this problem IMO....
have a read thru this thread: https://5series.net/forums/topic/776...th-new-wheels/
Black 328i 2008
2008 E70 X5
Black 328i 2008
2008 E70 X5
I have doubt about the quality of the rings installed. I got them from a local shop and I believe he didnt have the right size and just gave me the closest size. I believe the size i have is 74.6 I really dont remember.
btw I bought another rings from ebay size (72.6)but it was too small, i got the wrong size. Do u kno the right size?
thank you
You need to get plastic hub rings NOT the crappy metal ones VMR, AG, Miro, etc provide. You need 74.1 to 72.56 or 72.6.
Also, are you sure the wheels are properly balanced?
Michael
Acute Performance
Michael
Acute Performance
thank you
thank you
I guess you did not read the entire thread I linked..
http://forums.5serie...post__p__902588
and
http://forums.5serie...post__p__907438
Black 328i 2008
2008 E70 X5
I really appreciate ur help, I will order them today. wheels are balanced but Ill check them again and if balance needed ill do road force balance
