Spacers to reduce body roll?
Old 07-09-2010, 07:17 AM
Mr5
Mr5's Avatar
Does anyone have any experience with spacers?
I'm looking at this set: http://www.supremepowerparts.com/1444347/0/0/6461/2010_BMW_535I_XDRIVE_L6_3.0L_T_FI_(N54B30A).html
I'm trying to reduce body roll with the easiest and cheapest method.
I don't want to spend $1k on coil overs since I can't get springs alone because I own an X-Drive.
What do you guys suggest?
Are spacers (15mm) an easy "fix" to reduce body roll?
I have read up on the "added stress to the suspension components" and other negatives such as the spacers getting stuck on the rotors.
Old 07-09-2010, 10:26 AM
Cal@Jlevi SW's Avatar
Spacers will push the wheels out slightly, giving a better stance and will improve handling somewhat..but to really reduce body roll you should look into some sway bars...H&R makes some good ones and they are very reasonably priced. Please take a look at the below link for more information, and please let me know if you had any other questions or concerns.
Note: these Sway Bars will not fit cars with Active Roll Stabilization (ARS) AKA Dynamic Drive...
H&R Sway Bars for the BMW E60 & E63 [HR-SWAY60-10]
Old 07-09-2010, 11:18 AM
in addition stiffening up the suspension will reduce body roll as well
Old 07-09-2010, 11:09 PM
Seipäänreikä's Avatar
My Ride: 2008 Black E61 530Xd - M-sport - Comfort - Advantage
...A LOT!
Old 07-13-2010, 08:45 AM
Mr5
Mr5's Avatar
Originally Posted by Seip??nreik?
...A LOT!
I'd LOVE to stiffen up the suspension and do strut bars, but this is not really an option for me since my 535i is X-DRIVE.
CAL, it specifically says on your site that the strut bar will NOT work for X-Drive cars.
Also, to stiffen up the suspension, the only option I have will be with coil overs correct, or have I been misinformed?
Old 07-13-2010, 09:33 AM
for an XI you can do coilovers, or keep the stock shocks and go with H&R sport springs
Old 07-13-2010, 09:40 AM
Ricracing's Avatar
I got 12 mm SCC spacers rear and the Eibach Pro Kit and 19" Style 172M wheels
with 245/275 tires.
The car handles very nice.
Old 07-13-2010, 09:44 AM
dbae1978's Avatar
there are front and rear strut braces available for XI vehicles as well as coil overs. spacers will not improve/reduce body roll. the only possible way is to change out your suspension and add strut braces. I know you're looking for an inexpensive mod, but in your case there just aren't any. when it comes to BMWs you've got to pay to play
PM Nerweezy for your modding needs.
IE:
http://www.dinancars.com/store/home.php?cat=769
Old 07-14-2010, 08:07 AM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
M5 Rear sway bar also fits.....
Old 07-14-2010, 03:07 PM
E92-Lighting's Avatar
My Ride: Next Gen LEDS
i would look into front and rear sway bars, i got mine from H&R
Quick Reply: Spacers to reduce body roll?
