Spacers....need help with my 550
Old 03-14-2011 | 05:27 PM
paws's Avatar
My Ride: 2008 550i Space Gray and Black Dakota. Sports package with 19 style 172. First BMW and is AWESOME
As you might be able to tell I am novice at mods?.When I have my 172?s on my 2008 550 it seems like my back wheels/tires sit in some vs. flush with the wheel wells. Similarly when I have my 124?s on, see pictures. If I put on spacers on the back wheels will that help push them out?
Also if spacers will help will one set help with my 172s and 124s?
Thanks for the help
Attached Thumbnails Spacers....need help with my 550-124s.jpg   Spacers....need help with my 550-124.jpg
Old 03-14-2011 | 06:53 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
yes, the rear can definetly benefit with a set of spacers. remember that you need to get longer wheel bolts if you get spacers.
i think most will use a 12 or 15 mm spacer on the rear.
Old 03-14-2011 | 10:26 PM
sndohio's Avatar
My Ride: 04 545i 6 speed 92 535i 5 speed 88 325i auto
go with 20mm
Old 03-15-2011 | 04:59 AM
paws's Avatar
Thanks .....where do I buy spacers and the wheel bolts and are there different qualities of spacers? How do I know if I need 12 or 15? Do you think the same spacers will work with my 172 as well as 124s?
Old 03-15-2011 | 07:58 AM
ProMed's Avatar
My Ride: 535i
I went with 17.5mm in the rear from Turner.
Old 03-15-2011 | 08:00 AM
j0nblayz's Avatar
my guess is your not lowered, so you should be able to do 20mm in the back and atleast 12mm in the front. I would go with H&R spacers.. i have ran them on all my previous cars with no issues and they are hubcentric.
Old 03-15-2011 | 10:14 AM
paws's Avatar
Who is Turner?
Old 03-15-2011 | 10:17 AM
paws's Avatar
turboawd what make of spacer did you use?
Old 03-15-2011 | 10:23 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
To choose the right bolt length you just have to measure the thread length of your current bolts and then add the thickness of your spacer to it. For example if the bolt is 35mm long and you put a 15mm spacer --> 50mm bolts.
Turner stands for Turner Motorsport.
When you buy spacers for your, lets say, winter wheels, they may or may not be usable with your summer wheels. The summer wheels' width and offset are probably different, so that's why they sit differently in the wheel well. With the second wheel setup, the spacers (that were bought for the first wheel setup) may push the wheel too much out and this may cause tire rubbing the fender.
- Antti -
Old 03-15-2011 | 12:25 PM
ProMed's Avatar
My Ride: 535i
Originally Posted by paws
Who is Turner?
http://www.turnermotorsport.com/BMW-...l-spacers.aspx
Quick Reply: Spacers....need help with my 550
