Sound Upgrade Recommendations?
I recently picked up a 2008 535i, it has the stock audio package (no speakers in the rear doors, just bass & treble adjustment) Does anyone recoommend a solution that would improve the sound quality without hacking up everything?
I hear the JBL MS-8? Replacing the amp? (maybe a PnP solution out there)
Any help would be great!
Thanks!
Thanks!
My Ride: 2008 528i, AW
Thanks!
Thanks!
Here are some links to the items i installed:
Stage 1 kit: http://www.bavariansoundwerks.com/pr...es-M5-E60-E61/
JL Audio Sub: http://www.crutchfield.com/p_136XD30...0%2f1&skipvs=T
JL Audio Amp: http://www.crutchfield.com/p_1369313...ch=jl+audio+w3
another note: anyone interested in a sub INSIDE the cabin and not in the trunk (bmw trunks are super sealed its insane), the JL audio sub linked above is fantastic. It's small enough to fit perfectly behind the drives seat, only 5.25 inches wide, can easily be unplugged to remove in case someone needs to ride. All in all an easy solution for bass instead of hacking up the ski pass or getting super huge subs for the trunk.
Cheers!
Snitzl5
I installed a powered bazooka tube and after pointing it towards the rear im an very pleased with it.
My Ride: 2006 530i mystic blue
i dropped alot of wsted money on the stereo in this car. take my advice. replace the sock 4s in the front doors with 6.5s. u wuill have to cut them into the bottom of the door(custom) the4's offer no midbass and there freq. range sucks. u can replace the rear deck 4s for a aftermaket set so u can have some rear fill. u want your fade to be set up front more anyways. as for low end bass u can replace the two 8 inch speakers under the seats or just leave them alone. running a sub in the trunk is pointless unless u cut out a hole between ur cabin and ur trunk. u wont get the bass u want out of the sub if u dont. if u have fold down seats then ur a lucky man. im running one eclipse 10 in a sealed box about 2.0 cubes. facing the tailights. i have the box sitting about and inch from the tailights. it totally kills my useable trunk. kinda beat. the bass hit hard tight and clean for 1 10 at 700 watts rms. my two amps were run into a jl audio clean sweep. the clean sweep runs off the factor wirirng. if i could go back in time i woulda left everything alone.
My Ride: 2008 BMW 535xi Purchased 2/2011Sapphire Black MetallicNatural Brown LeatherPremium, Sport & Cold Weather
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
The BSW upgrade are crap, not worth the asking price!! get some rainbows or morels. here's a group buy on some rainbows https://5series.net/forums/topic/115...1#entry1362017
socale39
09-05-2023 08:30 AM
incoherent
04-15-2015 04:48 PM
