Can brake bleeding destroy the abs system
Old 08-09-2017, 03:25 AM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Default Can brake bleeding destroy the abs system
I have a 2010 model 528i.
I just did a 2 man brake bleed.
The person pushing down the brake pedal pumped the master cylinder very quickly while pushing the fluid from the reservoir to the calipers.
Is it possible he destroyed the abs system and that is why the brake pedal doesn't get hard now?
Old 08-09-2017, 05:59 AM
jgt
jgt's Avatar
My Ride: E60
Engine: N52
I highly doubt it.
It just sounds like you may need to bleed the ABS system using INPA.
Here's a starting reference point
https://www.bimmerforums.com/forum/s...o-bleed-brakes
Old 08-09-2017, 09:09 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
yep, sounds like you have trapped air. ABS unit is probably fine.
Old 08-09-2017, 01:46 PM
NoQuarter's Avatar
Engine: N54
What do you mean? As in pump-pump-pump without changing the bleeder screw open/closed?
Old 08-09-2017, 04:06 PM
cakes's Avatar
My Ride: 550i
Model Year: 2010
yeah sounds like air in they system. Also - a must when using the pedal bleed method is to put a small block of wood/rock behind the brake pedal so it doesn't get pushed all the way to the floor. The pedal never goes that low during normal driving, so you don't want to push the seals in the master cylinder all the way to the end.
