Sound from engine bay when AC is ON
My Ride: E60 530i
Engine: M54
Since last summer, whenever I turn on AC (auto mode), I could hear another set of sound on top of engine running noise. This new sound/noise goes up and down in pitch/amplitude when car acceleration. It was not there in previous 11 years. Also, cold air does not come out of vent as fast as before. It will take about 1 minute or more to feel the cold air.
AC system of my 530i has never been serviced since day 1 (12 years). What could be the cause of the extra noise when AC is ON ?
Thanks,
Ching-Ho Cheng
Thanks,
Ching-Ho Cheng
My Ride: 2006 530xi
It's hard to say without hearing the noise. It sounds like it is belt-related due to the change in pitch with acceleration.
The cause of the delay in feeling the cold may be unrelated to the noise - and related to the 'freon' level in the AC system. You could be low.
My Ride: E60 530i
Engine: M54
I hope that it is belt related. Changing the belt is much cheaper and easier than compressor replacement.
My Ride: E60 530i
Engine: M54
Unfortunately, mine does not go away. It is not a squeaking noise, rather it sounds like engine noise and deeper in pitch. It only goes away when I turn off AC.
My Ride: 2006 530xi
When the AC is on, the compressor clutch engages and there is a bearing behind that clutch that could squeak as it gets old.
My suggestion is to start the car, raise the hood, have someone turn the AC on and off and observe the compressor clutch and the timing with the noise. As you face the car, it is located on the lower left. You can find it by following the smaller belt.
Then take the belt off. Have someone turn the AC on and off with the car running again and see if the noise still happens. Spin the tension pulley by hand and see if you can reproduce the noise.
My Ride: E60 530i
Engine: M54
My Ride: E60 2006 sedan auto
I replaced both belts but after I replaced the serpentine belt I put the old aircon belt on and the noise had gone
Then I replaced the aircon belt as well
My friend has a 2007 525i and she had a similar noise
I changed the serpentine belt on hers as it runs the aircon as well
Since replacing there has been no return of the noise
But I replaced with the v serpentine belt which is unbelievably quiet
