After driving home from work today I heard a low hissing sound coming from the area of the trunk hinge - where the hinge comes out from the carpeted area of the trunk. It sounded very much like a slow, steady air leak. Only on the driver side and only audible with the trunk open. Any thought?
Air pressure is fine in the rear tire and I couldn't smell or feel any air escaping from the hinge area. |
Air pressure is fine in the rear tire and I couldn't smell or feel any air escaping from the hinge area. Is it possible that you heard the fans running? |
Originally Posted by Rudy' post='944430' date='Jul 16 2009, 10:52 PM
That area contains the power amplifier for the Logic 7 audio system which has multiple cooling fans that'll kick on if the amp gets too hot. I often will hear my fans running even after I've turned the car off if I've had the music volume up for some time.
Originally Posted by Thullz' post='945023' date='Jul 17 2009, 11:57 AM
That makes sense, thanks Rudy.
