Something wrong with the car today !
My Ride: 525i
basically not enough info.
Is the car running when you have the rock hard brakes or off? The picture shows no RPM so I guess it would not be charging. What is the voltage?
My Ride: 525i
it was in the garage, and i cant turn the car on either. How come all the electrics were working fine. First time i tried to turn the car on and saw a message saying low charging something. so i turned everything off, get the key out, put the key back in, hit the brake and now the brake is hard.
I tried to jump the car with 2 cables jump connected with each other but no luck.
Your brake is hard because you have no vacuum to the brakes with the car off so don't worry about that. As far as the battery is concern I would disconnect one terminal and charge the battery over night. Then have the battery checked for amount of voltage and load tested. The car may and may not start after it is fully charged.
My Ride: 525i
How can i charge it, any more specific info and instruction how to do this ? and should i disconnect neg or pos terminal ? thanks in advance man
dude you are scaring me with your lack of automotive knowledge.
Borrow or buy a charger.
If you are confident enough, you can pull the battery and take it to a parts store to charge and do a load test after it is fully charged.
Although it will work I do not recommend it as it can harm the charging vehicle's electronics, you can put jumper cables on and leave the running car running for 15-20 minutes(lights and a/c off). After which the BMW may start if there is enough charge built up in the battery, but it could have a bad cell.
Remember positive to positive and negative to negative, last cable to be mounted is at the running vehicle. Hook it wrong and the ECM as well as your Smart key will be fried.
My Ride: e60
ur both over complicating it
:l
take out the battery
take it to autozone
say u want it charged and tested
charge will take about 2 hrs and test is a few secs
...all this can be done for the fabulous price of FREE
fuck buying a charger or a tester when others will gladly do it for free
:l
take it to autozone
I mention that.
Problem is when you don't know how mechanically inclined someone is... well that's why I gave options. He can just as easily have AAA tow it to the dealer and let them deal with it.
