something is killing my battery
Surprised no one mentioned the MPM and/or the relay. Of course it may not be located the same. Mine was re-located by dealer under the driver's tail lamp.
http://tis.spaghetticoder.org/s/view.pl?1/08/88/47
"The time is reset by switch-on conditions, e.g. by a door being opened. This means: The vehicle is unable to go into sleep mode after terminal R is switched OFF. ne There is no limit to the number of times this process can be repeated. It could thus cause the battery to become discharged!ne The MPM goes into sleep mode approx. 1 second after the K-CAN goes into sleep mode. Before the MPM goes into sleep mode, the current switch state of the bistable relay is stored."
Ah that completely bypassed my mind...
The MPM is one little annoying component, and when the trunk of your car floods, your MPM is inundated with water. Check for any signs of burning etc., I've seen many MPM's go bad due to exposure to water.
I think this might be the best solution so far i will be replacing this asap ..my MPM did get wet last year but i never replaced it because it never gave me any problem until recently ....thanks ACHTUNG!!!!!!!!
Make sure you update us with findings/solutions so we can help another in the future. Who knows maybe they wont even have to post!
It worked perfectly my car started right up after about ten hours hooked up to the battery ...no more battery drain and the light by the automatic shifter finally goes out after 20 min....i love this site ....thanks guys for the help
...now i have to find a new spot to relocate this MPM SO THIS WONT HAPPEN AGAIN!!!
Vman33
Mar 14, 2022 04:43 AM
