Age old question:
I know there is no way to tell what software version you have other than by the dealer system. But there must be some way you can tell visually --- May be the way the iDrive looks, behaves, certain functions deferences between the newer and an older version. Does anybody have any experience/insight with this sort? |
Originally Posted by jagbagri' post='755402' date='Dec 29 2008, 06:34 PM
Age old question:
I know there is no way to tell what software version you have other than by the dealer system. But there must be some way you can tell visually --- May be the way the iDrive looks, behaves, certain functions deferences between the newer and an older version. Does anybody have any experience/insight with this sort? http://www.bimmerfest.com/forums/showthrea...light=drive+cip |
I've noticed that the start-up menu changed from mostly brown in the earlier version to mostly gray on the latest 31.2 upgrade.
Originally Posted by kgmccarthy' post='755432' date='Dec 30 2008, 01:40 AM
Actually, there is a way to check it indirectly via a hidden iDrive menu. The menu will actually give you a code called the "Target Data Status" which you can cross reference with the CIP version.
... Not really, unless you go through ALL hidden sub menus and check ALL codes. Different modules, different codes. When you perform the CIP/Progman update not ALL modules get updated. Therefore, it is not a 100% guarantee to see the actual "correct" code. Maybe, if you're lucky. ;) The only way to really know what version the OS is: you have to get the info directly from your dealer! |
| All times are GMT -8. The time now is 07:28 AM. |
