Software upgrade/New tires, and now my...
Had my 545 sport in for service recently. They did the software upgrade - can't tell which version, but assume it was 16.xx (work done in last week of May and I'm in Dallas). They also replaced my noisy Dunlops after about 6K miles.
Now the steering and handling of my car is way different from before. I had heard that 16.xx changed some things with the active steering, but this is a change for the worse. The steering feels much looser and lighter (more Buick-like, than BMW). Also, and I may be imagining this, but it also feels like the suspension is softer, as the car rolls and dives more on turns and braking.
Has anyone else experienced this? Could the new tires be an issue (they're the same Dunlops runflats as before, just a newer production date)?
Side note: the new software does seem to boot much quicker, but now I have more phone/bluetooth hiccups.
Thanks.
Thanks.
My Ride: Jet Black 545i
I think it's all in your heads... do you guys have any other proof other than "it feels" different?
I didn't know the 5 series suspension was electronically controlled... One of the reasons I bought a 545 was that it didn't have airbag suspensions like the E and S class have. Mercedes airmatic suspensions go out frequently.
If you had the tires replaced at BMW of Dallas, they are notorious for putting in 32 psi all the way around, regardless of model, etc. MY SA said it works fine. Go back to what is on your door post 36 front, 44 rear and see if that doesn't clear some of the handling differences you feel.
My Ride: MY05 545i Jet Black with Auburn interior. SMG, Logic7, Sport Package, Comfort Seats, Navigation.
JDN may be right regarding the softer suspension. I also felt the suspension went soft after coming back from the update. But as it turned out, the dealer has set the pressure at 32/34 f/r. I filled the tire back to 38/44 as per door label, and everything came back. I did notice the transmission and the throtle response were milder after the update though.
Originally Posted by TXPearl' date='Jun 10 2005, 08:06 AM
Had my 545 sport in for service recently.? They did the software upgrade - can't tell which version, but assume it was 16.xx (work done in last week of May and I'm in Dallas).? They also replaced my noisy Dunlops after about 6K miles.
Now the steering and handling of my car is way different from before.? I had heard that 16.xx changed some things with the active steering, but this is a change for the worse.? The steering feels much looser and lighter (more Buick-like, than BMW).? Also, and I may be imagining this, but it also feels like the suspension is softer, as the car rolls and dives more on turns and braking.
Has anyone else experienced this?? Could the new tires be an issue (they're the same Dunlops runflats as before, just a newer production date)?
Side note:? the new software does seem to boot much quicker, but now I have more phone/bluetooth hiccups.
Thanks.
Thanks.
[snapback]138229[/snapback]
Originally Posted by tomwid' date='Jun 10 2005, 12:13 PM
I think it's all in your heads...? do you guys have any other proof other than "it feels" different??
I didn't know the 5 series suspension was electronically controlled...? One of the reasons I bought a 545 was that it didn't have airbag suspensions like the E and S class have.? Mercedes airmatic suspensions go out frequently.
[snapback]138271[/snapback]
The BMW e60 does have the option of the Active Suspension, which adjusts the suspension in order to allow flatter cornering, while also maintaining a smoother ride on the freeway. I believe the system uses adjustable sway bars as it's main component, instead of airbags like the competitors.
What ever they use, it is awesome. I do believe this is part of the Sport Package.
Your car wouldn't have it if it didn't have the sport package.
Regards,
Michael
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by mehall2' date='Jun 11 2005, 07:05 AM
The BMW e60 does have the option of the Active Suspension, which adjusts the suspension in order to allow flatter cornering, while also maintaining a smoother ride on the freeway.? I believe the system uses adjustable sway bars as it's main component, instead of airbags like the competitors.?
What ever they use, it is awesome.? I do believe this is part of the Sport Package.?
Your car wouldn't have it if it didn't have the sport package.?
[snapback]138468[/snapback]
