Software Fault
My Ride: Delivered 30/11/04: 535d Sport, Carbon Black, Black Dakota leather, Media Package, Hi-Fi, Rear M Spoiler, Headlamp Washer, Auto dim/folding mirrors, Grad tint screen, Aux input,
Long Story Short....Shortish
Parked car Friday night, all fine. Saturday went to start car iDrive warning regarding lighting systems: check indictors, side lights, dipped beam, full beam.
Performed soft reset (sat nav pro), no change. Checked fuses, all OK.
Called BMW assistance; helpful lady took details and arranged for an engineer to come out to vehicle. 40 minutes later (pretty good considering there are only two working for the whole of Scotland!- which is a bit worrying), guy turns up and tells me that this is a new known fault with the coding, which is causing a problem with the lighting module,(My car was re-programmed in Jan '06 CIP 20.0 (I think) because the last one CIP 17.? had stopped the yellow eyebrow lights working). The solution, for the time being, is to do a full reset to clear the fault. Once done all seems to be well. Good service, nice guy.
He informs me that this is only temporary and it could last a day or two weeks, but that the only permanent solution is a full dealer re-code.
Apparently he has already had to do this to a 7 series as well.
Oh what great fun off to the dealer again.
Watch Out it could be you next!
Was this full reset performed at your location? Did u witness and learn how to do "full" reset?
The simple answer is the had to remove the battery supply for a short time, then reconnect. Then he used his BMW tablet (laptop) to do the diagnostic check.
I couldn't say whether removing the battery supply alone, would have provided a short term solution.
Wonky
04-12-2016 08:15 PM
