Soft "clunk" sound when shift into reverse
Hello all,
I noticed today when backing into my space at work a soft clunking sound when shifting my 2010 550i into reverse. It's not a loud sound at all, and is halfway between a click and a clunk (sorry can't be more specific).
Did a search and didn't find anything...wondering if anyone else has heard this sound and whether I should be concerned about something mechanical?
I have a sport auto transmission that I exclusively use in manual mode, and only about 5K miles on my car.
Thanks in advance.
-TA
Thanks in advance.
-TA
Thanks for the replies, guys. I just noticed it this morning, so I'll pay attention to see if it can be replicated.
Turboawd, from your response, it sounds as though you've heard this before with your car?
also, if you put your car in reverse when the engine is cold and reving higher, you're more likely to hear a clunk.
every rear wheel drive car has some drivetrain backlash to a degree. if it gets louder than normal or occurs frequently, then you might want to inspect the driveshaft, u-joints, etc.
5K miles? Probably just break-in. I would assume nothing worrisome. Could be metal to metal contact with new lubrication.as the components wear and get used to the oils used things should quiet down. Do you not hear this sound when you go from drive to park?
Same thing happens to me some times, I consider it normal. I usually shift from D to N (wait a second) then R to avoid this from happening. Not sure if this in a option for you though, as you have the sport auto tranny.
Drove my E39 to work today, so didn't have a chance to check. I'll listen more carefully in shifting from drive to park to see if I hear something similar. I am heartened, though, by the fact that this seems to be a common experience. Thanks for all of the replies.
