So, my water pump blew up.
Old 09-29-2010, 01:35 PM
LJTX545I's Avatar
My Ride: 2005 BMW 545i, Titanium Silver. Bridgestone 760s on Weds Bavaria II 18" wheels, standard sport pack size. Sport, AT. Latest job - NGK Iridium IX plugs installed.
there's a set of master RA instructions somewhere on this forum. You can find the part information here water pump diagram. Only tool you need is a 10mm socket wrench. Your call as to whether you want to replace the thermostat or the temp sensor, or any of the hoses. More tips on my thread.
Old 09-30-2010, 12:59 PM
ConviktColby's Avatar
My Ride: 2004 Mystic Blue Metallic 545I
i am doing the thermostat as well. Do i absolutely need to remove the pulley directly underneath the water pump pulley to reach that bolt?
Old 09-30-2010, 08:58 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
i ended up loosening that lower bolt with an open end wrench, to the point that it practicaly hit the back of the main pulley. i then pulled the water pump out with the bolt just sitting in the hole. if you need a little more clearance, you could loosen the main pulley bolts, so that it leans out a bit.
Old 11-23-2010, 06:12 AM
2exclusive's Avatar
i have a brand new OEM thermostat for sale if anyone needs it
part number 11537586885
$50 shipped
Old 11-23-2010, 10:09 AM
healthservices's Avatar
No, use a short gear wrench. I just did a Range Rover. It uses the same 545 engine. Was not hard to do.
ali-d1936
07-26-2015 05:32 AM
SayeedA
07-16-2015 06:57 PM
pantzjantz
07-07-2015 04:44 PM
JWMich
07-07-2015 06:13 AM
DAVE H
07-06-2015 12:27 PM
Quick Reply: So, my water pump blew up.
